pictsidhe
From before I got my SE, I suspected the regen braking could be used to tow-charge it.
I needed to move a dead car for someone today with my truck. So while we were in a towing mood, we tried tow charging my SE.
Yes, the SE will tow-charge! I started it up as normal and left it in max regen. At speeds up to around 35mph, I was looking at -0.9mi/kWh. Trip computer did not go negative and pegged at 20mi/kWh. That was despite finishing the short test with an extra 4% in the battery.
I suspect maximum charge rate is the same as DcFC, 49kW. So over maybe 45mph, you won't charge faster and you will need to do more miles. At some point, the motor may well get warm and throttle charging. 49kW is 65hp. I doubt that it is rated for that continuously. Teslas M3s aren't...
Depending on tow vehicle and road speeds, you may want to use low regen. Low regen may allow faster motor limited charging. Current is the main cause of heat and is approximately proportional to torque.
My 10' strap was scary short. I'll get a longer one to add to my charging kit.
