JyChevyVolt
Where's the tire pressure monitor with actual PSI information? Wife was driving with 11 PSI, screw embedded in the tire.
From my understanding, the TPM system does not show PSI nor does it tell you which tire needs inflation.
This just confirms my doubts about the Clarity TPMS. I bought the Vesafe and it seems to be quite accurate and reliable.
https://www.amazon.ca/Universal-Wir...&qid=1546017203&sr=8-19&keywords=tpms+systems[/I bought a similar item. Works great. Vesafe Wireless Tire Pressure... https://www.amazon.com/dp/B07CPYWVCT?ref=ppx_pop_mob_ap_share
it just measures differences in tire rotational speeds to deduce that one or more tires have different pressure.
I might get one of those but instead of trying to figure out where to mount the display unit in the car I'm thinking about keeping it in the garage mounted somewhere easy enough to glance at when I walk out to the car, assuming the range is adequate enough. Or maybe it's not good to power the display unit 24/7 so I could easily rig up a power switch for it since it seems to be USB powered. Is that better than having tire pressure in front of you at all times while driving? No, but it's a lot better than having to go around to each tire with a tire gauge which I currently do, but not nearly often enough. But if I had a nice little electronic thingy in the garage that will give me a near instantaneous tire pressure readings I would probably look at it almost every day. I would though bring it with me on long trips.I bought the Vesafe and it seems to be quite accurate and reliable.
I’m not even convinced it calculates pressure from rotational speed since you can reset it at any tire pressure.
I purchased this one, it works great... https://www.amazon.com/gp/product/B075848KTW/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1This just confirms my doubts about the Clarity TPMS. I bought the Vesafe and it seems to be quite accurate and reliable.
