***** Danger Will Robinson! *****
So you poked holes in your walls and floors? You sure spent a lot of money for a decidedly sub-optimal DIY solution. You really should not have used "extension cord" but #6 should be fine for 50A that you hopefully are not trying to draw. Most Dryer plugs are 30A in older houses not 40, Range plug might be 40A. Your 30A dryer breaker may allow you to pull as much as 32A for an extended period. This would be bad, and you will fry your breaker over time. It could cause a fire! For anyone who is charging at home and wants simple 240 to improve charge times I would recommend running some ROMEX or something to an outlet. You don't have to run 40 or 50 amps to get reasonable charge times. I highly recommend the clipper creek chargers they just work, and have a 24A (30A Circuit) units that you can plug in a standard NEMA 10-30R receptacle. By running much cheaper #10-3 romex ( < $300 for 100ft Home Depot ) on a fresh 30A breaker from your panel (HD < $20), just run it up thru your attic and drop it down inside a wall near where you want it. ( $15 maybe for a 10-30R and an old work box and cover plate ). You can pick up everything at Home Depot, or your local ACE hardware. Total cost - effort/labor: $325 maybe?
Charging at 5.6KW (~240 x 24A on a 30A breaker) is generally more than adequate for home for a number of reasons.
- Charging slows down at 80% (or should) anyway, and slows down even more at 90%.
- The slower you charge the better it is for the batteries.
- Most EV's will not charge over 7.2KW anyway. (40A / 32A)
- Most people who charge at home never go much below 50% charge.
- The time difference between 5600 and 7200 is not really much longer, like 20%, ie my Niro needs ~8 hours to charge from 20% to 100% at 7.2 and ~10 hours at 5.6. I RARELY get that low so generally my charge times are 5-7 hours, ... While I am in bed using Time Of Use
- Finally you can buy a standard inexpensive 30A HWH timer... ( I might note, this would also be a good place to tap your "shared" electricity from) and program it for your time of use hours, then just leave your car in charge all the time. This is what I do, that way if I get some free leccy from a station somewhere, I don't have to re-program the car every time, or mess with settings.
Pulling a breaker at over 80% of it's max rating for an extended period is a very bad thing.
