Right but I referred to that in the very next sentence after the one that you quoted. Sorry if I wasn't clear.2002 said: ↑
and by not fully charging and not fully depleting the battery.
Except for some BEV's with no backup, HEV's and PHEV's don't allow full charge/discharge cycles with most using a roughly 80/20% ratio. That's why they can easily make the 8-10 year mandated warranties.
And the point that I was making was in the next sentence after that:and by not fully charging and not fully depleting the battery. Of course we know that the system has a buffer on top and bottom
but I don't doubt that some battery longevity can be gained by steering even further away from the edges
Are your referring to my last statement "I don't doubt that some battery longevity can be gained by steering even further away from the edges"?Yeah, it's already done for you.
However the big question for me is how much extra longevity are we talking about? I am not ready to change my driving or charging habits just for the chance of a nebulous amount of additional longevity.
Until now I assumed that by longevity everyone means how long until the battery fails, not trying to avoid reduced capacity when the battery ages. If it's about reduced capacity then sure I agree it doesn't seem worth it to reduce battery usage now to try and avoid reduced battery capacity later. But I'm not sure if anyone is thinking that.I look at this way: What's the point of not using capacity today to HOPEFULLY retain some capacity tomorrow?
Thank you for the responses to this thread. These are some things I have concluded regarding battery life and drive modes:Are your referring to my last statement "I don't doubt that some battery longevity can be gained by steering even further away from the edges"?
If so then you are saying that the preset range limitation is set past the point where there would be any longevity gain by not charging to 100% or avoiding EV 0. I say we don't know. But I also say that even if there is any longevity gain we don't know how much, it might not be enough to be worth making any sacrifices in how we use our cars. Which is why I said a few sentences down from the others that you quoted:
Some may want to err on the side of caution, but personally I'm in agreement with you to not give up capability now if there isn't at least persuading evidence that it will have a noticeable impact later on.
2. For a BEV avoiding charging to 100% is more important than a PHEV because of the upper reserve built into the latter.
BEV's also have an upper reserve. Fotomoto mentioned some that don't, I am guessing those are older models.For a BEV avoiding charging to 100% is more important than a PHEV because of the upper reserve built into the latter.
Full discharge cycles are finite and it is beneficial to avoid them if overall battery life is considered important. I am not persuaded that battery tech is good enough that this consideration can be fully ignored over the useful life of the car.
As far as driving modes- the Clarity like most cars is essentially dumb- as it does not fully take into account your proposed route, weather, charging stop points and driving habits when determining how to function in normal mode. I believe the manual modes are designed to address this, but for some drivers a flex/smart mode that has user input and automated gathering of relevant information could optimize performance.
I am unclear if gear mode is a hold over from i-MMD designs on hybrid non-plugins that have much smaller batteries, or still useful for cars like the Clarity.
Good point on the lower reserve buffer, which I was aware of. But my point was to reduce the level of daily/normal discharge, while predominantly on electric and using minimal amounts of gas. I could also charge to less than an observed 100%- but at that point the tradeoffs are unclear to me given my commute is fixed. Also, Hondalink doesn't readily support charging to X percentage.BEV's also have an upper reserve. Fotomoto mentioned some that don't, I am guessing those are older models.
Neither BEV's or PHEV's allow you to fully discharge the battery. That's what we refer to as the lower limit, lower buffer, etc., i.e. 0 miles and 0% is really 20% or something similar. The question is whether 20% or whatever it is can still be too low for someone whose goal is maximum longevity, as opposed to reasonable longevity. Obviously reasonable is a subjective term.
Something to keep in mind is that while 20% or whatever it is is the normal lower limit, you can go below that by sitting for a long period of time with the car on, especially when using HVAC. SOC will drop below the normal 8-10% as displayed on the app to about 1% before ICE starts up. Someone who is concerned about going too low on the battery should probably avoid this if possible and not sit still for long periods of time with 0 EV range.
For performance (i.e. efficiency) yes. However using manual modes for battery and ICE longevity, which is what your original question was about, the jury is out on that.
If you are referring to i-MMD hybrids only, I assume that the tradeoff decisions were similar to Clarity. As to your question whether they went with i-MMD just because it's what they already developed, but not necessarily the best choice for Clarity, that is an interesting question, with what I assume is yet another elusive answer.
When Chevy first released the Volt, they were very cagey about whether the ICE ever connected directly to the mechanical drivetrain. Eventually they admitted it was necessary to achieve the greatest efficiency for cruising at highway speeds. Honda clearly came to the same conclusion when they designed the i-MMD system. If it didn't provide greater efficiency than serial hybrid operation in certain situations, there would be no reason to add Engine drive's complexity, weight, space requirements, and cost to the Clarity PHEV. Getting 42 mpg from a 2-ton car is very impressive IMO--Engine drive contributes to that efficiency.4. I am unclear if gear mode is a hold over from i-MMD designs on hybrid non-plugins that have much smaller batteries, or still useful for cars like the Clarity.
You can charge less than 100% by using scheduled charging, after you get experience with estimating charging times you could probably get within 5% of a target. Probably what you were referring to by "doesn't readily support".Good point on the lower reserve buffer, which I was aware of. But my point was to reduce the level of daily/normal discharge, while predominantly on electric and using minimal amounts of gas. I could also charge to less than an observed 100%- but at that point the tradeoffs are unclear to me given my commute is fixed. Also, Hondalink doesn't readily support charging to X percentage.
