Tapping or Creaking Noise when coasting at low speed
  • Thread starter Thread starter wizziwig
  • Replies Replies 560
  • Views Views 203K
Do you hear the same noise?
  • Yes, I hear the same noise
    Votes: 60 69.8%
  • No, I don't hear the noise
    Votes: 26 30.2%
  • Total voters
    86
It does solve your current problem. Whether the new motor and gearbox will develop the same issue in the future is still unknown.
I had the same issue with my Kona. They replaced the both the motor and gearbox, and the problem has not come back. That was a year and a half ago, and 18K kms since.
Nice to hear that. I talked to my dealer about terminating the leasing contract and signing a new contract on an EV6, so I will do that. Waiting time 7 months, so I will get the EV6 in March/April 2022. 325 hp AWD. But I am sure they will fix my e-Niro before that. Used e-Niros are in demand so prices are high, very high.
A follow-up to my post #394: At 10,000 miles I began noticing the same dreaded tapping noise from our 2019 Niro EV motor that other owners have reported. My local dealer’s service department confirmed the motor needed to be replaced, covered by the warranty. My encouragement that they open a tech line with Kia on the topic helped them come to that conclusion. I made sure they ordered a third-generation E712 motor to replace my first generation E710. It took about three weeks for the new motor to arrive and to schedule a repair appointment. What was estimated to be a one day repair turned into three and then four days. During that time, they were counseled by a Kia field representative that in order to install the replacement motor the transmission would also need to be removed. I am pretty sure this was the first time the service department had attempted this major EV repair so I was apprehensive that everything would be put back together correctly. I got the car back yesterday and so far everything seems to be holding together. I hope the E712 motor solves the tapping problem and I can enjoy my Niro again.
Change the engine mounts to lower the sound level. I the customer can´t hear it; problem solved by "patching".
Kia is fully aware of the motor issue at this point so their first action should be to replace the motor.
Yesterday someone in the Facebook group said there is now a service bulletin. I bet service centers have to follow these to be reimbursed for warranty repairs.
Adam Roman on Facebook's Kia Niro EV Owners Club Group said:
The head of the service dept at my dealership just called me… Kia has just released a service bulletin that the fix for the tapping motor is a “motor mount kit”. He is speculating that somehow the motor/gearbox is vibrating in a way that is causing the problem/ruining the ev motor. The service bulletin requires that they disassemble both sides of the drive motor first to see if they are damaged, then replace any damaged parts and then reassemble and install the motor mount kit.
=AZUe1G44LfYU30ipUCZvRdOiF3ZSrrtGsyOrjjbqecHjYETrGpdtZuNI8MI3MfSgoor0xYsfn4NExoxBrUSLB3tpjqgUTReXK3uzg2aPIuLp8HB_KJzV-IpwDelMSclx1adoDeKu9kM419pCuETD8MJDiJ1xwytBW1aAhiH1NC-5Q_TriPNtFgky9tpRF8Ar9Tc&__tn__=R]-R =AZUe1G44LfYU30ipUCZvRdOiF3ZSrrtGsyOrjjbqecHjYETrGpdtZuNI8MI3MfSgoor0xYsfn4NExoxBrUSLB3tpjqgUTReXK3uzg2aPIuLp8HB_KJzV-IpwDelMSclx1adoDeKu9kM419pCuETD8MJDiJ1xwytBW1aAhiH1NC-5Q_TriPNtFgky9tpRF8Ar9Tc&__tn__=R]-R']Facebook Link
So maybe it is a tolerance problem brought on by motor mount issues. Maybe some mounts have defects or are installed improperly or some other assembly problem mispositions the motor and different mounts can put it in the right place.
Once the sound is heard at all, they really need to do something to the motor too since some level of damage will have occurred.
6500 miles; I hear nothing except typical windup under heavy acceleration...
Mine didn't start until about 10k miles or more.
My dealer also says this is "normal" and the tech who checked it out ostensibly drives a Niro EV as well. That doesn't make me happy but it's nice to know I'm not the only one and I'm not going crazy heading something "no one else" hears.
Good example of the noise captured by another owner. It's extremely loud in this video because he captured it from under the hood. The file I attached in the first post was captured from inside the cabin. I'm taking my car in for service tomorrow.
no bulletin number on that post on FB
I just came across this:
#TSB_ELE234_R1
that might be it
https://m.carcomplaints.com/Kia/Niro_EV/2019/tsbs/tsb-tsb-ele234-r1.shtml
f
ound the first lines of the summary on this page. It looks like it is. I. wonder if we can get a copy!
https://www.aboutautomobile.com/Technical-Service-Bulletin/2020/Kia/Niro-EV/Electrical-System
TSB Number:
TSB_ELE234
NHTSA Number:
10191531
TSB Date:
April 30, 2021
Date Added to File:
May 3, 2021
Failing Component:
Electrical System
Summary:
Technical service bulletin: drive unit inspection & replacement for ev motor rumble noise - this bulletin provides the procedure to inspect and repair the ev motor drive unit and reduction gear on some 2019my~ niro ev (de ev) vehicles produ
https://static.nhtsa.gov/odi/tsbs/2021/MC-10193244-0001.pdf
Dated May 13, 2021.
Thanks for finding it Jim. I searched around some at NHTSA but must not have used their search tool properly. The bulletin even has recorded sounds from inside the cabin of the vehicle. Not sure if this is the same effect, but it might manifest differently from car to car or depending on how developed the problem is.
The bulletin flowcharts are consistent with what many reported their service centers did, trying things like motor mount and reduction gear replacement.
My (wife’s) car is currently at an Atlanta dealership’s service center being “diagnosed.” It took 3 months to get the appointment and, so far, they’re on day 3 of having the car. They acknowledge hearing the issue but are “trying to figure out what’s causing it.” Attempts to engage in constructive conversation with the service manager were met with animosity and insult. Attempts to figure out how long he thinks he’ll have the car for this “diagnostic” stage were equally poorly received. I’ll keep the thread updated, but I’m gearing up for a multi-visit, multi-year process to try and get this fixed.
My (wife’s) car is currently at an Atlanta dealership’s service center being “diagnosed"....
Spoke with someone else in the service center today and he said they've opened a ticket with Kia Corporate and are sending diagnostic information back and forth.
He said that the sound I'm hearing (which they confirmed they hear too) is not related to the existing TSB. The sound I hear is identical to what's been reported on this thread.
I can pick up the car for the weekend (because "they won't send us anything over the weekend") but I need to bring it back on Monday so they can reopen the ticket and continue where they left off.
Here in the States we will get the run around until KIA corporate issues a recall with the Warranty rate for the service. My local dealership was similarly unwilling.
Unless there's a dash light alert or catastrophic mechanical failure, I doubt any US dealer will help us stave off the problem.
I think the coming EV6 rollout is KIA corporates focus, not those of us who already bought into the brand.
Just wanted to add a note to say I've got the noise on my 2020 Niro. I leased it in May of '21 and started hearing the noise a couple of months ago, with only about 1,200 miles on it. I haven't decided what to do yet as I really don't want to go through all the headaches many have described here, and be without a car for awhile, only to have them not fix it.
Ended up leaving the car there over the weekend because it didn't make much sense to pick it up Friday night only to have to take it right back Monday morning. Didn't hear a peep from anyone all last week.
Called the dealership this morning for an update and was told that they haven't heard anything back from Kia Corporate about the "readings" they sent them and have a note on the ticket to follow up today with Corporate to see what they want them to do. I'm not hopeful that any progress is made this week and am now using these posts to document my correspondence in case the timing of things is needed in the future. This looks like it's going to be an ordeal and communication so far has been...lacking.
