Take Care with Transmission CVT Fluid replacement...
Robert_Alabama
Dealer today changed the oil and transmission fluid in my Clarity. When I was checking out, I decided to make sure that they put the DW-1 fluid in it. They called back to service and were told that the fluid sent from parts was put in it. They eventually got to parts and found that the wrong fluid was used (probably the HVEF type 1.0). They changed the fluid again and supposedly put the DW-1 in it. I guess I should have told them at the beginning to make sure that they used the right fluid, but you'd think they would know what to put in a car that I bought there. Regardless, thought I'd mention it if anyone else is about to get the dealer to change the CVT fluid...
It is wrong on Amazon, as well. See Below:
I changed mine myself and used the valvoline max life cvt trans fluid. I know that everyone isn't comfortable using this fluid but my car has been driving smooth for about 2 years since I did it. It meets all the specs except for honda's endorsement.
