Long time problem. I have an OBD2 reader now. Connected the recorder after I had charged the car to 80% overnight.
The dealerships say no error code, no problem.
I contacted Kia they say I need to work through the dealerships. I can't afford to throw away $30,000. What can I do?
- I started the car and charge dropped from 80% to nearly 0% almost instantaneously.
- I stopped and restarted, no change
- I reconnected the car to charger, it returned to 80% in 12 minutes.
- This is impossible with a 1KW charge. I filmed the dash read out for the 12 minutes.
- I started the car and the dash read that the car was now 100% charged.
- Again after 12 minutes at 1 KW, it is impossible to go from 0% to 100%
- The charge read 100% the entire 42 mile trip to work.
- This can be seen in the OBD2 data under “State of Charge Display %”
- The “State of Charge BMS %” OBD2 data shows 80% the entire 42 mile trip.
- The “State of Charge BMS %” and “State of Charge Display %” OBD2 data show this entire timeline
- I do not know if it is related but “Cell Voltage 68” has problems. All the other cells seem uniform.
