I confess to not fully understanding the Prius drivetrain, but in that vehicle, being a form of series-parallel hybrid, it makes at least some degree of sense. Basically, since the Prius is capable of running entirely on the ICE, since it includes a full transmission with a mechanically linked motor/generator, I can see how you could mechanically or electrically decouple the larger EV motor and just let the ICE (presumably allowing assist from the smaller hybrid motor?) provide all power to the wheels until the battery had reached a safe level.There has to be some engineering sense to this for both Honda and Toyota engineers to design the system this way. As mentioned by @bfd this behavior was commonly observed in the plug-in Prius. See this thread and this one from PriusChat for examples.
It doesn't exactly make sense to me from a basic energy flow standpoint, but because of the ICE-centric design I kinda get how that might be the way you'd end up doing it.
There doesn't seem to be much documentation on the PHEV Clarity's powertrain available at this point, but the Honda description is of a different system, where the ICE is normally only connected to a generator, and the mechanical transmission only is engaged when the car is at cruising speeds, which is much closer to a series hybrid with a little bolt-on parallel hybrid action for highway-speed only.
In this case, I just don't see how it would make any sense to have the ICE running when the battery was full. When you're accelerating, you want the electric motors doing the work to draw down the battery, so any energy being produced by the ICE at idle is a disadvantage (and that's if the ICE transmission is even set up to be able to accelerate the car from a stop). At cruising speeds, same. The only use of the ICE would be to provide mild compression resistance on a gentle downhill gradient, but once you touch the brakes it's going to either have to regen or just use the calipers.
I'm not sure I follow. Yes, an ICE can use compressive heat generation and the exhaust system to engine brake, but are you suggesting that it's actually putting reverse load on the generator from the battery pack in order to force a charge level reduction? It's mechanically possible, but sounds nuts to me.But an ICE can dissipate energy as heat, even if no energy is going into the generator or the wheels, and that seems to be how the system is designed.
Every vehicle on the road prior to ten years ago had friction brakes as the prime means of slowing down, so this isn't exactly an unusual situation, but they do have the ability to use compression braking to spare the calipers, so your theory is the only thing remotely resembling logical I can come up with either.Going downhill with a full charge is exactly the situation that several of us have described for when the ICE comes on for no other apparent reason. You do ask the question that's in my mind as well: why can't the system use the friction brakes instead of rigging up the ICE for engine braking? One guess on my part is due to safety and liability reasons. You can have the situation where someone lives at the top of a long hill (some Prius owners in Colorado esp. describe this as a common scenario). If the car only uses the friction brakes to burn off the excess energy, it's possible that the brakes could overheat and thus create a safety hazard.
If the regen has maxed out the battery pack, the car only has two means of burning off excess energy: brake calipers or compression braking in the engine. In order to keep the brakes from overheating on a long downhill, it might be firing up the ICE entirely with the intent of using it with the mechanical transmission to do compression braking. It needs to be running for this, which would explain why it would have to stay on. I would wonder if the little "you're using the transmission" circle would appear all the time in this situation, if it exists.
However... the original post in this thread is not describing this situation:
If the ICE started up as soon as the car left the driveway, the only way the battery could be overcharged is if it was overcharged when it pulled in, which would require the car was fully charged elsewhere then driven downhill all the way home.2. Last week, with early morning temps in the high 30s (daytime temps in the low 60s), my ICE came on when I pulled out of my garage. My battery was fully charged as usual (see image below).
Rajiv: I don't suppose you live at the bottom of a long hill and charge at work? If not, it seems more likely this particular case is either something to do with temperature management or flawed firmware relating to same.
That would be mechanically and electrically possible, but sounds insane to me. It seems more likely, if anything (as I note above) that it might use the mechanical transmission to do engine braking in lieu of regenerative braking. Although that sounds odd to me as well.I'm trying to imagine how the Clarity can use the engine to "burn off excess energy." Could there be an energy-wasting mode where the motor/generator reverses it's torque and uses battery power to resist the torque from the engine it just started?
I have a coworker who is very knowledgeable about hybrid powertrains, so I'll try to corner him at some point and see what a professional's insight into it is. I'll report back if I learn anything illuminating.
