If you're not going to start your car for 2 weeks or more, you should always put the 12V battery on a
good and proper battery charger.
Unfortunately, it's hard for the typical person to know if a (12V) battery charger is good, or just a bunch of marketing BS.
So, I suggest that people buy the
Battery Tender brand-name products. That's what I use on my two cars and lawn tractor that sit during the winter. Yes, I have separate
Battery Tender chargers for each.
All you need is a trickle charge.
I use the cigarette lighter adapter.
I leave the charger unit on the concrete ground, and run the wire into the car, then shut the door on the wire. That's fine. And, it makes sure that the charger unit gets plenty of air flow.
I don't like "wall wart" chargers.
So, I don't like the cheaper .75amp $25 charger.
https://www.amazon.com/Battery-Tender-021-0123-Junior-Charger/dp/B000CITK8S/
Battery Tender
Battery Tender 021-0123 Junior 12V, 0.75A Battery Charger
#1 Best Seller in Battery Chargers
Price: $25.88
But, that charger does work fine!
I have one, as a backup, in case one of my other units breaks or gets broken. More likely to get broken with me.
I use the cigarette lighter adapter, instead of the battery clips. It just plugs right into the charging cable.
https://www.amazon.com/Battery-Tender-Cigarette-Lighter-Adaptor/dp/B003E02MMC/
Battery Tender
Battery Tender Cigarette Lighter Adaptor
Price: $7.64
I use the .8amp charger, since I don't like "wall wart" chargers.
https://www.amazon.com/Battery-Tender-021-0123-Junior-Charger/dp/B000CITKCE/
Battery Tender
Battery Tender 800 is a Super Smart Battery Charger that will Constantly Monitor, Charge, and Maintain your Battery. It's Encapsulated and Protected from Moisture by an Electrical Insulation
Price: $36.75
Fwiw, many of the junk battery chargers just have "on/off" cycles. That's not good, nor what you want. The Black and Decker charger that Home Depot sells is like that. There are a number of electrical reasons why that is bad.
Good Luck!
