If your stability control light on the dashboard comes on intermittently it could be the first sign of a leaky tire, even before the flat tire indicator lights up. I noticed the stability control light flashing during left hand turns and sure enough a tire on the right side was leaky. So don't panic if your stability control light on the dashboard comes on intermittently - check your tire pressures first. And be extra glad you read the forum post that tells you how to add a compact spare to your Kona (you did get that spare, didn't you?)
