Stability light coming on intermittently? Check tire pressure first.
  • Thread starter Thread starter C02less
  • Replies Replies 1
  • Views Views 998
C02less
If your stability control light on the dashboard comes on intermittently it could be the first sign of a leaky tire, even before the flat tire indicator lights up. I noticed the stability control light flashing during left hand turns and sure enough a tire on the right side was leaky. So don't panic if your stability control light on the dashboard comes on intermittently - check your tire pressures first. And be extra glad you read the forum post that tells you how to add a compact spare to your Kona (you did get that spare, didn't you?)
My go to screen is tire pressure, always, and is pretty darn accurate. But if another item is displayed by preference, this is useful information. Thanks :)
