Smart key fail
hobbit
I wish the search facility here wasn't so awful, or I would have gone looking for an answer before posting (and I haven't been on here in quite a while).
Anyway, my smart-key system seems to have died on its RF side, no longer detecting keys around the car and the RKE buttons don't work at all, either of the 2 fobs, fresh CR2032 battery inside. The "limp mode" function where you push the power switch with the fob right next to it *does* work to start the car, so between that and the metal key to enter I can drive, but it's a pain in the butt. Next thing to try is power-cycling the like 4 fuses that power the SKS module, as a friend has experience with keyfobs and receivers getting out of sync somehow.
Anyone had this sort of issue? If I can reset/fix/whatever myself I'd really rather not involve a dealer, but if the SKS module itself has died that is deeply buried under the dash and hard to get to...
_H*
Wellp ... as of this morning, everything appears to be back to rights with the Kona fobs.
The fix? Well, today we learn something about primary lithium coin-cells. Their open-circuit voltage can easily be deceptive. In fact, a battery that measured slightly higher would drive a fob than one that measured lower. Turns out that their means of dying is to develop higher and higher \*internal resistance\*, thus they must be tested under a modest load to check their true health. I clipped 200 ohms across my meter leads (about 15 mA worth at nominal voltage) and saw the voltage go \*way\* down -- one to less that 0.2V which clearly wasn't going to let anything produce meaningful RF.
By contrast, open-circuit voltage on most alkaline cells is a good indicator of their health, although some of the cheapass ones go high-internal-R after a while too.
To their credit, the CR2032s I had in there for what, 5 - 6 years since getting the car held up pretty well. The cells have a propensity to self-degrade just in storage too, as the "new" ones I had on hand seemed a bit wheezy under load-test too, but good enough to keep me going for a while. tl;dr, nothing apparently wrong with the SKS module itself so I never wound up power-cycling anything to try and force resets, etc.
_H*
