I have had several incidents where I intended to ship forward / reverse and because I did not have enough pressure on the brake pedal the car only shifted to neutral ... and then when I thought is as going to be in reverse ... it started drifting forward. If you are in a tight area you could drift into something before you knew you were out of control
