JonR
No. Definitely not.Are there two "different" suspensions (probably bushings) for SEs with run flats vs conventional tires?
So then the suspension on the SE is a compromise for conventional and run flats?No. Definitely not.
If you are running in GS, you can't change bushings anyway. I think all the F56s from Justa to JCW use the same arms, bushings, hubs.I don't think the US cars come with run flats. That's why I threw the question out here. I think other countries come with run flats. After I confirm that, I want to compare the difference.
I went from run flats on my 1 series, and had to change bushings for autocross/track handling purposes. I dont plan on autocrossing the SE with run flats. My question is about street driving. Are there two "different" suspensions (probably bushings) for SEs with run flats vs conventional tires?
You are missing my question. I didn't need to do anything to my 1 series to go from run flats to conventional. I dont need to do anything to the SE to go from conventional to run flats on the SE.No, you don't need special suspension to handle OEM sized runflat tires that have a high enough load index for your car. Tire Rack and Discount Tire both will show you tires that are compatible with your car based on the exact model. You can double check with the manufacturer's website too if you are still worried about it.
But again, I don't recommend runflats. The handling, ride quality, and noise level is worse with runflats.
I want all seasons on the car, and am thinking run flats for peace of mind. With the battery range, anywhere I go without a charge will get me back home. <<<WITH A FLAT RUNFLAT TIRE>>
Daughter killed two sets of tires in a two month period. One got a slice on the sidewall, other got a 3" screw that got the sidewall. I want to blame her, but it could have happened to me too. Just lousy luck.I’m not denying your want or need for this kind of peace-of-mind, but I’ve had four on-the-road punctures in 40 years and a million miles of driving, and two of them were my fault for being a cheap ba$tard and not replacing my worn OEM tires when they were well past due. And Montreal roads are famous for being among the worst in North America, making Detroit’s look like they were recently paved! I used to take people around, visiting from overseas, and they’d remark, “Wow. I didn’t know Montreal got bombed during the war!”
Just seems like an undue hardship and expense for what IMHO amounts to a very small risk.
That sounds nice. Snow, salt, darkness, and terrible roads. /sAnd Montreal roads are famous for being among the worst in North America, making Detroit’s look like they were recently paved! I used to take people around, visiting from overseas, and they’d remark, “Wow. I didn’t know Montreal got bombed during the war!”
But, did the BMW engineers design/install different parts on cars that came with run flats v conventional. Discount, who now owns Tire Rack go by dimensions, they dont go deeper into the suspension. Do SEs come from the factory in a country other than the US with run flats? And if yes, is every part of the suspension the same?
I didn’t mean to sound preachy and stuff. Everybody’s reasons are their reasons. All good!Daughter killed two sets of tires in a two month period. One got a slice on the sidewall, other got a 3" screw that got the sidewall. I want to blame her, but it could have happened to me too. Just lousy luck.
I had to drive the SE in -4 F weather yesterday. I know I did damage to the tires, and will replace them sooner than I would like. Since the SE is also used by my wife and daughter, I would rather not have to deal with the phone call. If I was the only one driving, I would probably be playing with the suspension like I have to most cars i've owned over the past decades of driving.
I don't know who at Mini to ask, or how to find out if run flats are standard in a country other than the US.
Didn't take it that way. Driving 40 years and had the same experiences as you. Lived and drive in Manhattan too.I didn’t mean to sound preachy and stuff. Everybody’s reasons are their reasons. All good!![]()
Thanks. Now the question is whether the bushings are different on the NZ SE. Or, has run flat technology gotten to the point where the ride is the same. If that is the case, then folks with 15 year old cars like my 1er that put new run flats on will have different handling characteristics - not that most old car buyers would notice it.
Front springs are very similar to F55 but I haven't measure them, yet. Rear measure as F54.That sounds nice. Snow, salt, darkness, and terrible roads. /s
I guess the upside is a more functional government, less guns, and healthcare.
I don't think any market got runflats. I believe all of the members on minif56 have mentioned they got summer tires.
But for what it is worth, the suspension parts are mostly the same between the Cooper S and the SE. The only differences appear to be subframe and mounting points which is likely to get the extra 18mm of ride height. The S comes with runflats and the SE comes with summer tires.
https://www.northamericanmotoring.com/forums/e-mini-2020/350939-lowering-springs.html#post4572413
The front springs appear to be the same between the S and SE. The rear springs appear to be from a Clubman model. So really, the SE is just a parts bin car with parts from the Cooper S and the BMW i3s.
I'm surprised MINI made changes to the SE's suspension. If the regular F56 suspension mounts work OK, why do you think they didn't use them in the first place? Did the change come with the 2021 SE? Does this unique mounting system make 2020s special and more valuable?Front springs are very similar to F55 but I haven't measure them, yet. Rear measure as F54.
The SE is jacked up with springs and I believe slightly longer shocks. The subframes are indeed different, but do not affect the ride height. Early SEs had different rear arm front mounts, which could have altered ride height, but later ones use the same as all other F56s.
Yeah, like the 85.5 and 86 944 that take Fuchs wheels, but don't take the Rabbit steel control arms, or the later, many around, but not really rebuildable control arms. Instead they have their own, not many around, oddball control arm that also is not really rebuildable. On the bright side aftermarket arms are like $1,500 last time I checked.I'm surprised MINI made changes to the SE's suspension. If the regular F56 suspension mounts work OK, why do you think they didn't use them in the first place? Did the change come with the 2021 SE? Does this unique mounting system make 2020s special and more valuable?
If you message me your VIN, I will open two windows in realoem.com and compare part numbers of the suspension bushings. I have a feeling the high performance summer tires on my SE are not going to feel very good this summer after driving in -4F and snow this past week.Yup, can confirm NZ has run flats as standard on the SE coming from the UK, I would assume that it is the same as with Australia.
I also will assume that the bushings are the same with the SE arriving at the US from the U.K.
Many summer tyres can be damaged if you drive on the at all below 20F.If you message me your VIN, I will open two windows in realoem.com and compare part numbers of the suspension bushings. I have a feeling the high performance summer tires on my SE are not going to feel very good this summer after driving in -4F and snow this past week.
On the bright side, the car with the winter tires is back on the road with a new radiator, and the temp will be in the 40s and 50s the next few weeks.
