The electric is not for everyone, today. The person who lives in an urban environment and travels every day coming and going from work, recharging from his own house, is a good example of who will have a good return on investment. Instead, the cab driver, traveling all day, travels about 800 km without time to recharge, not worth it. There is no way to accommodate enough battery power in a vehicle that can handle such an autonomy, nor will the recharge time be sufficient.
Another worthwhile case: anyone who uses a motorhome has time for multiple stops, if they have recharging points along the way, will be a case for good return on investment. But ... what if there are no recharge points? If the places you will travel are far from the cities, you probably will not.
But, and what if the vehicle can generate its own energy?
Here is the hook in this project: a creative design, that can put enough solar panels in a vehicle to generate energy that can supply the path; evidently being a vehicle destined to make several stops along the way, evidently in adequate places (sufficient space), and at the same time discarding in the set what is not essential.
The worksheet that is part of the project demonstrates the energy viability and the cost / benefit ratio, which is largely favorable to investment. Provided that the ideal environment for this vehicle is not the urban environment (where space is limited) nor long trips without stopping. If the user really needs to enter an urban environment, it will be possible; but will have the small inconvenience of requesting an emergency recharge from any wall socket (which can take from 6 to 8 hours), or get a parking lot for a full day with sun, in some place without shadow, occupying the equivalent of 3 seats.
This independence in relation to recharging points has a huge advantage: eliminating the cost of recharging, which will add to the savings in the electricity bill, and even in rent, if the person has the ideal of living in the vehicle.
Including in the project a electric tricycle (recharging also on the panels) for short travels around, exploring the surroundings, order supplies, and also for get the best place to park.
The driver needs to be aware that the actual autonomy will be dependent on the battery charge; so when it reaches 60% it will turn on a yellow light signaling that it needs to look in the GPS somewhere near to park; when it reaches 55% it must be arriving at the place. In this way, you will be able to maintain a minimum level of charge and maximize battery life, which accounts for most of the costs of the project, not only for the cost itself but for the need to switch over within 10 years.
