If I floor the accelerator to pass while the Engine Drive clutch is engaged, my Clarity disengages the clutch and switches from Engine Drive mode to Hybrid Drive mode, which maxes out at 181 hp. Does your Clarity instead stay in "gear mode" and shoot forward with greater acceleration than when you floor it in Hybrid Drive mode?Honda also allows the 103 hp engine to directly couple with the drive train between 45 and 65 mp for more passing acceleration.
I have driven in Gear mode at 85 MPH. Stays locked in normally.I have never observed this Engine drive mode above ~73 mph (~2650 RPM)
With the engine off, the Clarity PHEV's battery can provide only enough electricity for the traction motor to produce 121 hp. The 181 hp number requires the engine to be powering the starter motor/generator.The battery alone pushing the electric motor is able to output the equivalent of 181 hp to the wheels with engine off.
Somebody needs to pull out the battery and everything under the Clarity PHEV's hood, then install a conventional 212-hp engine and transmission and add enough bricks to make it weigh the same. Then they can stage a drag race against an unmodified Clarity PHEV to answer this burning question.
The electric motors in my factory have a rated HP, but the overload systems have time delays that will allow the motor to run at 20% over rating (212 is 17% over 181). This is industry standard for electric motors.I am skeptical that the 181hp motor could produce 212hp
Many conclude that the extra 31 hp is through direct connection of the engine through the wheels via the clutch. My only point is that this is not possible since to get the 212 - 121 = 91 hp from the engine, you'd need to be at ~5000+ RPM, which would mean if the clutch was engaged the car would have to be going ~137+ mph.
Ok, the 181hp motor can temporarily provide 212hp. It will need to receive sufficient voltage and current from the ICE driven generator to provide 91hp to reach that figure. The batteries provide 121hp. Is the ICE generator capable of providing that?
I’ll happily accept the tax credit as long as they give one dollar to any industry. I would like them to eliminate all credits and incentives for pretty much everything, in every industry imaginable out there, but that will never happen.Well I will go contrarian here again. I think ridiculous is strong. I own the car and agree with the majority of his review. It’s not like he tears it apart. He says the good things too. And his bullet points of pros and cons at the top address most of the deficiencies in his review you point out.
All are entitled to differing opinions, and everyone uses their cars differently. A lot of people don’t commute. And some don’t qualify for the tax credits, or choose not to consider any car that does on principal/political persuasion. I am opposed to the credits, but admit I took it. But as a fiscal conservative I’d be happier if the whole program was cancelled. Feds and state should do better things with tax dollars than making large down payments on brand new cars for people who don’t need the financial assistance. And all the credit does is cause instantaneous depreciation of the car value anyway...so for some there not as much gained as it seems.
I like my Clarity, but it’s not all that and a bag of chips. Many times I have thought an Insight or Accord hybrid may have been a slightly better choice for me. Agree length of Accord is same as Clarity, but in weight and secure handling there is no comparison...Clarity is nearly 800 lbs more, and the suspension and tires simply can’t handle it. This has been my biggest complaint about this car from the start. Reminds me of driving a 10 year old Buick Park Avenue. And if that’s what you like, it’s a perfect car. But this is not a drivers car. His complaints are similar to Consumer Reports and I know a lot of people here got bent out of shape over that review too.
But I have to admit I find a good amount of fairness and reality in both of these reviews.
