As
@Ohliuw says, your location (labor rates), length of wire run, and lack of capacity in your breaker panel requiring additional work will affect the price. I hope you’re not in California as all reports are that installations are sky high there compared to my area.
I would first suggest you check that you have 2 adjoining empty spaces in your breaker box and measure the length of the wire run to where you want the outlet. (Not a straight line, but up the wall across the attic and back down for example.)
Then get rough estimates over the phone but don’t mention the words EVSE, charger, solar, electric car as they will almost guarantee higher prices. Just say you want a 40 Amp (assuming a 32 A Level 2 EVSE) outlet in your garage for a dryer or welder. Even better if you know the plug configuration to tell them.
Normally a 32 A EVSE uses a 40 Amp breaker with 8 gauge wire unless the run is unusually long or your trying to future proof. You can price these 2 items and an outlet at your local big box store to get an approximate idea of how much the materials are and then keep from being over charged.
Many have saved hundreds by not asking for anything related to EVs.
And finally if you’re a DIYer, you can save a lot by fishing the wire between the outlet and breaker box, leaving some extra at the box and just paying an electrician their 1 hour service rate to hook it up. This way you don’t come into contact with any live components and you have a licensed electrician sign off on it. I did this and bought the breaker for $10 plus $40 of wire and $80 for an electrician’s so it was less than $150. It only took him 30 min to hook it up. (Yeah, my middle name is cheap)
