Cash Traylor
Greetings,
If you have time and these items, I would greatly appreciate some data. I can only compare my car to itself and I think I found a BMS variable but need to compare it to some other vehicles of varying age/SOH. Anyone with a really new car that can report this with a recent BCT would be great - the OBDII was only $12 on Amazon. Anyone (@StickWare ) that has a really high use vehicle would have great data too!
I am working on a project and don't want this to take anyone really any time or spending any money. If you have an OBDII wifi or bluetooth scanner and an Android based phone or device, can you download Car Scanner ELM OBD2 from 0vZ (or update to latest if you have it). Since the PID and calculation formula vary app to app, this is the only way for me to know the Clarity HV data is "apples to apples" so Torque Pro etc won't work. The free version should work fine for this.
For my car the report for this would be:
2018, 15400 miles:
If you can participate, my sincere thanks, if not - no big deal and thank you for reading.
Best wishes,
Cash
P.S. Tweaking the equations used on this and another PID project.
https://app.calculoid.com/#/calculator/78363
Wonder if I ask to go test drive a new Clarity with OBDII tucked in my hand would attract any attention....
- Use Honda Honda/Acura Hybrids connection profile
- Turn your car to the second accessory mode (second press of power button without break) and be sure to have your headlights and air conditioning off (completely).
- Use the "All Sensors" option and you can enter the search to type in Battery to reduce the list to what I would like to know.
- Confirm your HV Battery Current is at or below 1 amp or wait for that to stabilize below 1 amp for your readings. On this (-) reports are charging, (+) reports are discharging.
- Year of Car and Mileage
- BCT "If Known" and age and mileage of that report (skip if you don't have it)
- From Car Scanner (make sure you report values under these names only) There are other Battery and HV info reported that are under different formulas.
- Hybrid/EV Battery System Voltage (V)
- Hybrid Battery Pack Remaining Life (%) (this should be the same as your HondaLink Reported State of Charge)
- Battery Cell Max State of Charge (%)
- Need your full charge (charger stopped) data
- Some other point in the middle or lower range of charge
2018, 15400 miles:
- 342.9v, 100%, 96.27%
- 335.6v, 90%, 88.5%
Best wishes,
Cash
