ProspectiveBuyer
Curious what the pros and cons of using regenerative paddles are. I've tried paddles and normal braking. Not sure what difference it makes.
Braking (without the paddles) also generates electricity, and I don't need the distraction, so I largely ignore the paddles (and routinely get EV range around 60 miles per charge during Urban commuting). Sometimes, on the highway, I'll play with the paddles - and I believe that the brake lights illuminate once you get to level 4 (4 chevrons).
Here's one thread about this: https://www.insideevsforum.com/community/threads/clarity-regen-paddles-vs-braking.961/
No, having four chevrons showing does not light up the brake lights...at least on my Clarity. It's no different that downshifting a car with a manual transmission—brake lights don't come on then either.and I believe that the brake lights illuminate once you get to level 4 (4 chevrons). Here's one thread about this: [URL said:
They are useful for long mountain downhills to relieve fatigue on your leg and that makes the Clarity safer than non hybrid cars for that situation (no overheating of friction brakes and recharge the battery to boot!). I have noticed that the brake pedal can elicit a far stronger level of regen braking than the 4 chevrons with the paddles. If you're coasting down a hill or a freeway offramp on 4 chevrons, hit the brakes and you'll see a significant increase on the power meter. The regen system can provide an impressive amount of braking on its own.
