Ray B
I have a very repeatable driving pattern and the end of my daily return journey involves a 207 ft downhill slope (according to Google maps) for a little over a mile which adds some regen energy back into the battery. I decided to employ the 'Car Scanner' app to log the data from my OBD-II scanner and I added in my observations of the EV range at the top of the hill and when I got to my house. In ECON mode I made sure to do the same speed (37 mph) on the ACC and I swapped from ACC to paddle at a specific spot where the road flattens as it approaches a stop sign. So I tried to repeat this over the past couple of weeks to observe whether things like the SOC of the battery affect the regen.
It turns out that it does, but not in the way I was expecting. I had observed earlier that my gain in EV range by the downhill stint was much greater when the SOC was close to full, compared to when the battery was closer to empty. I did confirm that, but it appears that the actual gain in SoC is greater at lower SoC levels, and the system curtails some of the regen power at high SoC (say greater than 70%). In these summer months it is not really noticeable in the feel of the regen nor in the deflection of the 'needle' on the dashboard, as it is only a ~10% difference. Temperatures for all of these tests were ~80F give or take, windows down, no AC or other big power drains.
I expect that if I repeat this test in January when temperatures are below 0 C, I will observe a much more muted regen current at high SoC and somewhat normal current at low SoC. I may also run tests in SPORT mode to determine how much it affects the regen.
Here is the graph of the results:
