How would you compare the handling of your Mini and your Bolt? Not even in the same league, Mini is hand's down better, Mini is somewhat better, etc.
Handling? The Bolt is heavier and sits higher, with an inferior suspension. I mean, the Bolt is good for what it is, but it is nothing compared to the Mini.
Here's a quick comparison I left on facebook for general performance of the Bolt against the SE:
Driving - the SE is a sports car with go-kart handling. Acceleration is similar between it and the Bolt but the SE has almost no body roll and tight steering. The Bolt is sloppy by comparison.
Acceleration - similar in both. Similar power/torque although the SE applies it much more smoothly. The Bolt has more wheel spin from a jackrabbit start and is a bit touchier on the acceleration.
Regen - both have true one pedal driving although the Bolt’s Max regen is stronger. You don’t need to use the brake pedal on either with proper planning.
Technology - the Bolt wins here. It has a much larger screen and better features overall. The SE is more about the drive.
Navigation - not an option on the Bolt. I use CarPlay. Comes standard on the SE, complete with “green” routing options and the ability to locate and plan charging stops along the way. You can also find charging stations nearby in an impromptu manner, in case you find yourself unexpectedly low on charge. All easily accessible via intuitive voice commands.
Charging - bother have 7.xkW level 2 charging and ~50kW DC charging. The Bolt tapers its charge rate at 55 but the SE maintains full rate to 80%. This actually makes traveling with them similar, except for the first leg.
Range - Bolt is 238 and SE is 110 on the EPA scale. However, the SE has a heat pump and the Bolt does not. So lately I have been getting about 150 miles from the Bolt and 95 miles from the SE. the winter range drop really is that small at least at the moderate temps we’ve been having.
