Geoff Shelley2
I'm interested in your opinion about electric traction drive range extenders. Both generally and more specifically linear generators like this one www.youtube.com/watch?v=u4b0_6byuFU . Please comment.
BobThe example has too much vibration. Opposed piston engines have similar efficiency and inherently less vibration. The proposed Wankel even lower vibration in a smaller package and more compatible with smaller generators.
Bob
Can you point me to a website or other information about those two options. Because I thought 40% efficiency pretty awesome and the size 535 mm x 210 mm x 200 mm quite awesome too. Perhaps my conversion math is off, but isn't that 21" x 8.26" x 7.87"? About the size of an average carry on luggage? And it weighs about 40 lbs. Is the Wankel + generator or the opposed piston engines + generator you're referring to smaller and lighter than that?
Thanks!
Each engine has its own challenges and we really need to see them sized for an existing range extender. For example, my BMW i3-REx, 24 kW, 640 cc, liquid cooled, motorcycle engine.
- http://achatespower.com/our-formula/opposed-piston/
- https://jalopnik.com/mazda-officially-announces-the-return-of-the-rotary-eng-1829459947
- https://spectrum.ieee.org/cars-that...liquidpiston-unveils-tiny-but-powerful-engine
No problem. It is my hobby.Thanks for the info.
Try to find a BSFC chart. One of my favorite sources are the SAE papers.I could not see from the websites any stats on thermal efficiency or size or weight. . . .
The vibration problem can be solved in a 4-cylinder configuration with piston motion timed to avoid rotary and linear motion. Alternatively, 2-cylinders along along the piston center would work but be a little long.I think I'm still a fan of the linear generator for now . . .
