1) Max range when 100% charge shows as 41 miles. Is that normal or is something up with my battery? Max range is supposed to be ~47 but is part of that due to the recharge from breaking? Seems low to me, but my main commute is under 30 so its been fine. Just wasn't sure what other people see as their max range on electric. My kids get a kick out of watching it increase 1 mile when it charges while coasting / breaking
2) I've had it happen 2 or 3 times now (1 month ownership) where the car will not use any electric even when set to Econ mode and HV off. Normally the blue (electric) meter fills about 80-90% of the spedometer, but it will be 100% white and use gas, even though I'm at 100% battery and in econ mode.
I'm not sure what is causing it, but I'm thinking it might be related to the climate control as it seems to happen only if I've pre-warmed the car (while plugged in). I also turn on the heated seats (love em!) almost all the time right after starting, but it might play a part I'm not sure...
Has anyone else seen this problem? If I swap to HV I can get it to show a 20% or so blue bar which disappears quickly when accelerating so I end up burning some gas when it should be 100% electric. Toggling sport mode on/off, HV on/off (holding will say its fully charged), and econ off/on won't seem to reset it, but it does show up properly the next time I start the car after parking for a few minutes.
Overall I'm loving it, 700+ miles and besides a big roadtrip its been all electric. Filled up the tank (6 gal or so) today for the first time.
