Poor man’s trunk liner
Fast Eddie B
Carrying on in my tradition of “cheaping out”...
A trunk liner is a pretty utilitarian piece of kit. I found this at WalMart:
You just use scissors to trim to fit. Even has a formed cutout to access the hole for the storage compartment.
Nuttin’ fancy, but should get the job done:
I hadn't thought of getting on of these, but checked it out anyway. On amazon.com in the states, $28. On amazon.ca in Canada, $120. I don't think so.
I did exactly the same as you, and it works excellent. 5 minutes of scissor work...sorry no photo of mine but it looks almost exactly the same as yours and it covers every contour surprisingly nicely. No regrets. This is the one I bought off Amazon:
https://www.amazon.com/gp/product/B06XDJM14B/ref=ppx_yo_dt_b_asin_title_o09__o00_s00?ie=UTF8&psc=1
Do you think the generic mat with the size 55" x 31.5" is enough to fit? of course trimming will be needed. Just not sure about the 31.5" is long enough to cover the back
I think that would be fine.
As you can see in the photo in my first post, the mat does not extend all the way forward. But I think it will suffice for protecting the main trunk area, which I’d guess will cover well over 90% of our usage of that area.
Not even close if you want full coverage. Tape measure is clear on this. If you don’t mind exposed carpet up front then obviously it’s fine and wide enough.
The one I bought and linked above was 44” deep, and I trimmed very little off that direction.
130736BF-E52E-4C99-9C86-742DCF73AB79.webp 3EA3ED9E-E4C8-4767-9C19-5063B9F970CE.webp
If anyone is curious, here is mine after 4 months of use and abuse. Just scuffs, full coverage, never moves, sits flat, and covers 100% of carpet. See my earliest link above for the actual product I purchased from Amazon.
That $100+ mini tray from Honda accessory book is a sad joke in my opinion. It sent me shopping, and I rolled the dice on this $27 option and in my opinion won the roll...I recommend it and like it.
