The question came up over at the SpeakEV forum so thought I should not miss the opportunity to bore owners here as well.
It seems to me that using a simple reading of current data from any of the popular OBD apps such as Torque Pro you can quickly calculate how many full-charge-equivalent cycles your battery has endured since the BMS was last reset.
The CCC and CDC registers are cumulative coulomb odometers and represent accurate measurements of (Ah) units going in and out
separately. All you need to do is add them together and divide that sum by twice the battery capacity, 180 Ah. I've plotted it out over 300 km just to show how that accumulates over SoC usage, not evenly due to regen adding to the charging accumulation, CCC.
As you can see I have only 6.75 of these cycles accumulated between my last BMS reset at Campaign 196 in Dec 2020 and about July 2021 when I took this data, about 2745 km. Extrapolating to my total odometer reading at 19,600 that would put me at ( 19,600 / 2745 ) x 6.75 =
48 cycles total.
To put this into perspective, the cell life is specified at around
1200 cycles down to 80% SoH.
One reason to plot this is that the rate can be estimated with a linear trendline. The slope of the trendline is the estimated cycle increment for
every 100 SoC percent points charged or discharged, so that the slope has to be multiplied by 2 to make a full cycle, or 200 SoC points.
So, 2 x 0.659 = 1.32 full-charge cycles are accumulated every time I've utilised 200 SoC percent steps no matter how I do that, either driving or charging.
As an example, if I charge 10% then drive and use 10%, that's 20% accumulated and 0.2 x 1.32 = 0.26 cycle is used up. You might expect that to be 0.20 and it might if you were on the flat going at a constant speed.
The reason the factor is more than 1.00 is purely because of small amounts of regen occurring as you drive. I'll note that this particular 300 km drive was very hilly so the value could be lower for a Kona used on flatter roads.
