I cannot image it takes 16.9kWh.
Just last weekend, I charged from 10-99% SoC, and the Kill-a-Watt read 16.57kWh for that session. It definitely takes around 16.9kWh.
I rarely charge from 10% SoC, so the formula I use to predict energy needed for a full EV charge (keeping in mind that below 10% SoC is not usable for EV operation) is as follows:
Energy to charge = 90%*(Kill-a-Watt reading)/((SoC @ end of charge session)-(SoC @ beginning))
Hope that clears things up.
I think that 100% SoC means that the battery is
fully charged. If you your claim that it actually means "fully charged - buffer" to hide a "top buffer", than I would expect that at 0 miles EV it would show 0% SoC instead of 10% (two bars), to also hide a "bottom buffer".
I think that SoC displayed by Honda Link is the actual SoC, and that controller allows battery charge/discharge between 10% (or so) and 100%.
P.S. I am an EE, which doesn't mean that I am right (story of my life
Also an EE here. Allow me to nerd out with you.
If you've ever messed with lithium batteries, you'll know that their behavior is nonlinear. They can be overcharged and over-discharged beyond safe capacity, and any off-the-shelf BMS will reserve buffers, some visible, some hidden. I can confirm for you that my 2018 Clarity reports 0.0 miles EV range, and will refuse to run off battery power once there are two bars on the dash, and the SoC readout is 10%, as reported through HondaLink and OBDII scanners. The space between 10% and 100% SoC is what I refer to as EV capacity.
Nominal battery capacity is larger than usable battery capacity, which is larger than permitted capacity, which is larger than EV capacity.
Based on pre-delivery inspections, the
nominal capacity is around 55Ah@348V ≈ 19kWh. This would strongly suggest the 17 kWh advertised is whatever Honda's proprietary standards deem to be "
usable."
The
permitted capacity is the portion of the usable capacity which the BMS will allow the car to charge or drain before it forces the vehicle to shut off. This is represented by the % SoC, as read through HondaLink or OBDII.
The
EV capacity is the portion of the permitted capacity which the computer will allow the motor to consume in EV mode before starting the genset to stabilize the charge. This range is 100-10% on the SoC readout. When most people refer to "usable" capacity, this is what they're talking about, because it's very difficult to discharge below 10% SoC.
We know the EV capacity is below 15 kWh, because users here report a charge from 10% to 100% SoC with a level 2 charger takes around 14-15 kWh from the wall. For me, it takes an average of 16.9 kWh. From this, I know that my wall-to-battery efficiency cannot be much higher than ≈85%.
Anyway, we're getting away from the subject matter. If you want to know how much power you're using, get a Kill-a-Watt. It's cheap and reliable. If you need a level 2 charger, get a JuiceBox or similar smart setup.
