Now that we have some deliveries , has anyone measured the temperature of the obc (on-board charger) either by digital infrared thermometer or (carefully) with the back of your hand?
A report from New Zealand with an ambient of 25c measured over 55c even with the coolant flowing. Note further post where the charging rate was automatically reduced to 16A @70% during this event.
http://www.mykonaev.com/forum/viewtopic.php?f=11&p=178#p175
The voltage there is similar to N.A. (240V)only diff is at 50 hertz.
I believe the obc on the Kona is 7.5kW @ 240V =31.25A ( not a lot current for causing that kind of temp)
Does the Kona have a current selection in the settings to reduce this heat?
