Official range rating 110 miles
  • Thread starter Thread starter DucRider
  • Replies Replies 20
  • Views Views 4K
EPA Application:
https://iaspub.epa.gov/otaqpub/display_file.jsp?docid=48730&flag=1
349V, 93.2 Ah battery
Calculated capacity of 32.5 kWh matches the reported 32.6 within rounding errors
Reported usable capacity has been 28.9 kWh, but it took 34.3 kWh to recharge on both the UDDS (city) and Highway test cycles. This would equate to an 84% charging efficiency which is very low indeed.
Test data indicates a average voltage of 362, and 83.6 Ah used, which would equate to ~30.25 kWh usable. That would put it at ~88% efficiency which is on the low side of most test data, but not out of range.
They do indicate 230V used while charging, but that shouldn't impact efficiency
I believe the usable capacity is a bit more than the reported 28.9 kWh
Those aren't ranges, those are MPGe for city/hwy tests (something they think is more important for consumers to know than range apparently)
EPA Application:
Whoa, the testers' Actual Distance Driven was 166.967 miles (or was that "drive" on a dynamometer?):
Thanks for having better reading skills than me. Did you calculate the city/hwy range numbers?
Years of seeing people look at the Monroney at shows and confuse MPGe with range. Many were shocked that the Bolt was rated for only 118 when they heard it was supposed to be over 200. Most buyers are much more concerned with range than relative efficiency, but the label requirements highlight MPGe.
Compiled test data:
https://www.fueleconomy.gov/feg/epadata/20data.zip
Label ranges are 70% of tested results to better reflect real world averages. (Sometimes a manufacturer will voluntarily lower them further)
32, 33, 34
Make sure and select the "20 EVs" sheet from the tabs at the bottom
Thanks so much! I kept searching the main page instead of looking for the EV tab.
For ALL THOSE TURNED OFF BY THE RANGE
The Mini Cooper SE's Range Is Fine
https://jalopnik.com/the-mini-cooper-ses-range-is-fine-1841279991
Jalopnik had a nice article on those who criticize the range
Excerpts
The average American driver spends about 27 minutes commuting to work one way. In distance, that’s just over 12 miles. Most days you go to work and come home, maybe stopping at the grocery store or swinging by the middle school to pick up your kid on the way home. If you’re only doing 30 miles of driving per day for an hour or maybe two, why would you need more than the 110 miles of range that the Mini Cooper SE provides?.......
No, the Mini Cooper SE won’t work for you fringe cases who drive half way across Texas to get to work. But here’s the kicker, not everything is about you. And you don’t have to make it about you. This one is just for the suburbanites who park in their own garage every night and work just a few miles from home.
We need to have a conversation about what exactly electric vehicles are for, and how we travel as humans. No, EVs aren’t for everyone yet. But they are excellent at filling some of our needs all of the time, or all of our needs some of the time.
All I need to know about the Mini is that it’s a Mini.
Another article , this time from Car and Driver
https://www.caranddriver.com/reviews/a30689865/2020-mini-cooper-se-drive/
The Electric Mini Cooper SE Is About More Than Just Range
Steer the Cooper SE onto an on-ramp, and it hangs on ferociously. It wouldn't be a surprise if, in terms of sheer grip, this is the most capable Mini.
.....Sometimes a low base price applies only to a stripped-down model that nobody really buys, but the Cooper SE's entry-level Signature trim includes almost everything anyone would want: LED headlights, heated seats, navigation, Apple CarPlay, heated mirrors and washer jets, black leatherette upholstery, camera-based automatic emergency braking, and 16-inch wheels. Signature Plus ($34,750) adds 17-inch wheels, power folding mirrors, rear-park distance control, a panoramic moonroof, and an upgraded Harman-Kardon sound system. The Iconic trim ($37,750) brings a head-up display, a bigger central touchscreen, and wireless charging (for your phone, not the car), along with some trivial frippery such as a leather steering wheel that's different from the standard leather steering wheel. The only common option that's conspicuously absent across the board is adaptive cruise control. You know, the Leaf offers adaptive cruise control.
We typically charge to 90%.
My equipment for work would fit if I needed to use the Mini for work. I normally need more range than that for my work day though.
The thing that impressed me the most is how the Mini SE has similar efficiency to the Tesla Model 3, and that the range test ended within a few cm of the charging cord length, whew, amazing "planning".
