I've had my Kona for 6 months. Around the 6000 km mark, I noticed a noise while at slow speeds when engaging the brake pedal or applying the regen paddle, while coming to a stop. Sometimes it is almost imperceptible and other times very apparent. I've seen other threads regarding a clunking sound when applying the brakes and that the correct sized brake clips are required to fix the problem. I think mine is different, in that, both the hand paddle and the brake pedal are associated with the sound. The best way that I can describe it, is, a gurgling sound. The dealership says it's normal. What do you think? Anyone else experience this?
