Looking for new tires and it seems like it will have to be new wheels as well. Has anyone had any interference with a 225 size?
You should expect a similar range hit with any performance tire, regardless of the widthThat sucks
@MichaelC updated that data with a stock size pilot sport tire on the next page, and others have compared range loss from just offset. Basically ~5mi of the 20mi loss with 225s is from the width and ~15mi is from the rubber
As this paper describes, the SAE created a standardized test for rolling resistance that employs a drum pressed against the tire being evaluated. It's too bad the tire manufacturers don't reveal the results of the test (and if they don't perform this SAE rolling resistance test, what's up with that?). The number (dimensionless, as the paper explains) would be a better guide than a vague, limited set of lettered grades.Makes me wonder if the 225 width tire is a "high B", just below the threshold of a C rating...
This summer, I should collect some new data with lower rolling resistance tires in the wider profile fitment.
I am actually in the process of buying the new tires now, and am quite frustrated that the EU market has different fitments available than the US market--this adds some challenge when cross-shopping with the EU tyre labels. EU gets Goodyear Eagle F1 Asymmetric 5 in 225/45R17 fitments (Fuel: A / Wet: B / 70dB for 94Y rated tires), but it appears the US doesn't get any 17" sizes for that model. It looks like I should be able to get Goodyear Eagle F1 Asymmetric 3 in 225/45R17 (Fuel: B / Wet: A / 69dB for 91Y rated tires), which seems to be my best option for a sporty summer tire in that size that doesn't have terribly high rolling resistance. Interestingly, the 215/45R17 91Y tire has a Fuel rating of C. Makes me wonder if the 225 width tire is a "high B", just below the threshold of a C rating...
My SE come with basic Hankooks 195/55/16 and I believe those are most comfortable tires bc of the biggest side wall as you go to 17” or 18” is less tires caution and a ride is not comfortable you need to learn how to handle a car a bigger tires don’t make you good driver and a front drive car as SE is the most forgiving car for a beginners or we all race car drivers owning Mini Cooper,s SE ? to try put big tires on small car . W hat about range you do 80 miles ?..on big tires?My statement is a joke bc you should put the best tires on EV for efficiency and factory is doing that.
Have you considered attempting coast down testing? Wouldn't be as accurate as what the OEMs do but I think you could extract a change in drag from different tires.
I assume the OP really wanted Nokian winter tires but was frustrated they're not available in sizes the SE can use without spacers.I’m still not sure why this thread is titled “Nokian tires.”
Finally stopped snowing here, and I'll be switching to summers next week! Pirelli Cinturato P7 RFT Summer 205/45R17 88W (Fuel:C / Wet:B / 71dB)
I thought the P7 was an all season tire and the P1 is the summer version. But, I could be confused.
