New here, and building a free EV charging cost spreadsheet. What should it cover?
  • Thread starter Thread starter BenGC_EV
  • Replies Replies 12
  • Views Views 53
BenGC_EV
Hi everyone,
I'm Ben, from the Gold Coast in Australia. I worked in the car trade for 14 years and I drive a BYD now.
I've been making a few spreadsheets to make life easier for myself and other EV owners. They're mostly cost calculators, because I never found one that answered the questions I actually had. The one I'm proudest of works out what a single charge costs, say from 20% to 85%. It allows for the power lost while charging and shows the range added, the cost per 100 miles and what the same distance would cost in a gas car. I've done US, UK and Australian versions so the units are right for each.
I'd like to make it more useful, so I'm after opinions from people with different cars and different power plans.
What do you wish a charging cost calculator did that the ones you've tried don't? Time-of-use rates, home solar, cold weather, public fast charging, a log of every charge?
I have a free one-tab version I'm happy to share if the mods are OK with a link. I sell a bigger version too, so I wanted to ask before posting one.
Cheers,
Ben
Some things I'd want in a charging cost calculator: (1) Charging losses as an input. Wall-to-battery efficiency is often somewhere around 85-90% on AC, and worse at low amperage or in the cold, so let people override the default. (2) Multi-band time-of-use rates, ideally with separate weekday and weekend schedules. (3) Public DC pricing models. Per kWh, per minute, session fees and idle/congestion fees give very different totals, and per-minute pricing hurts most above ~80% when the car slows down. (4) Subscription break-even, i.e. monthly fee vs. the discount per kWh. (5) Home solar: use the export rate as the opportunity cost of self-consumed energy. (6) A winter range factor, plus the extra energy for preheating. Cost per 100 miles (or per 100 km) next to the gas comparison is a nice touch.
Thanks Bohdan, that's a really useful list. There's plenty in there I hadn't thought through properly.
Charging losses and a cold weather setting are already in it, so it's good to know I'm on the right track there. The per minute public charging point is a good one. I hadn't really thought about how much that stings above 80% once the car slows right down. Session and idle fees too.
The subscription break-even and using the solar export rate as the real cost of power you use yourself are both smart ideas. I'll have a think about how to fit them in without making it too fiddly to fill out.
Out of interest, what are you driving, and do you mostly charge at home or out and about?
One thing I’d add is a simple charge log that records start/end SOC, kWh added, charger type, tariff band, session/idle fees and ambient temperature, then calculates effective $/kWh and cost per 100 km. That lets people compare their estimate with reality and spot when AC losses or cold weather are worse than expected. A CSV export is handy for tax or rebate records. I’d also include separate fields for taxes/GST and any minimum session charge, since those often decide whether public charging is actually cheaper.
Thanks Ben. I drive a VW e-Golf and charge mostly at home, so a home charging cost calculator is exactly what I'd use. I'm planning to upgrade it soon, so I'm curious how much a newer car's efficiency changes the cost per 100 km. How does the BYD compare on that for you?
Thanks sophiabrown, a proper charge log is a great idea. Checking the estimate against what actually happened is the bit I care about most, especially in winter or on a slow AC charger. Good shout on GST and minimum session charges too. A couple of dollars minimum on a short top up can wreck the numbers and most people never notice.
Bohdan, the e-Golf has a good name for being efficient, so a newer car won't always beat it by much. Cost per 100 km mostly comes down to how many kWh the car uses per 100 km, times your home rate, plus whatever gets lost while charging. A bigger, heavier car can end up costing more even if it's newer.
I haven't got clean numbers for my BYD handy, so I'll pull them from my last few charges and post them here rather than guess. What are you looking at upgrading to?
One thing I'd add near the top is a monthly total, not only a single-charge number. What I actually want to know is what a month of driving costs with the charging I can get.
For the US numbers, at 1,000 miles a month I worked out estimates from about $54 to $182, depending on the state and whether the driver had a plug at home.
I'd also keep the location and date with each public price. The same network charges very different amounts station to station, so one national rate comes out wrong in both directions.
And I'd make the gas car's mpg an input rather than a fixed figure. At 25 mpg versus 35 mpg the comparison can look quite different.
One gap in the list is demand charges. Some US utilities bill residential EV plans on peak kW as well as kWh, so a cheap energy rate can still cost a lot if you charge at full power. A peak kW input and a $/kW field would catch that.
Thanks gearup and Kelvorn, both good ones.
gearup, a monthly figure makes a lot of sense. Most people think in terms of the monthly bill, not one charge at a time. That spread of $54 to $182 shows how much having a plug at home matters. Fair point on keeping the location and date with public prices too, and I'll check the gas mpg is easy to change rather than stuck on one number.
Kelvorn, I'll be honest, demand charges weren't on my radar for home charging. Is that common where you are, or only a handful of utilities? A peak kW field sounds easy enough to add if enough people are on those plans.
Bohdan, I haven't forgotten the BYD numbers. They're coming.
Good catch, Kelvorn. It's not only the south either, some of the Arizona utilities have home plans with a demand piece too. The part that trips people up is that it's usually the house's peak they bill, not just the car, so the oven and the AC can set it on a day you barely drove.
If you can fit it, peak kW and $/kW is worth a column. The DC sites get billed the same way, and it's a good chunk of why fast charging costs what it does.
Thanks gearup, that's a handy bit of detail.
I hadn't clicked that it's the whole house's peak that gets billed, not just the car. That changes things a fair bit. You could charge gently overnight and still get stung because the oven and the air con were both going at dinner time.
So the car side alone can't really predict it. I'm thinking it would work better as a spot where you put in the peak kW from your own bill and the $/kW rate, rather than the sheet trying to guess. Would most people on those plans find that figure on the bill, or is it easier to get from the utility app?
Interesting point about the DC sites too. That explains a fair bit about fast charging prices.
I'd check the bill. If the plan has a demand charge it's its own line with the kW and the rate. Some utility apps just show usage and cost, the demand line usually isn't in there.
And if there's no demand line on the bill, they're not on that kind of plan and can skip the field. Worth a note in the sheet so people don't go hunting for a number that doesn't exist.
Thanks gearup, that settles it. The bill it is.
Good call on the note too. I'll word it so that if there's no demand line on your bill, you just leave it blank and move on. Nobody wants to go digging through a utility app for a number that isn't there.
Appreciate you sticking with the thread. It's turned into a better list than I expected when I kicked it off.
