Aircooled6
I live in Dallas Texas. What is the most efficient color for the Bolt; dark or light?
Greetings fellow north Texan!
If you’re worried about efficiency based on the car color... don’t. It makes only the slightest of difference.
But if you really hate hot cars in a blistering 100* Dallas summer then i would go for a white or silver Bolt. Skip the dark grey or black.
But I have a dark grey bolt in Dallas and it doesn’t make much difference. It helps more to park in the shade or in a parking garage. A car parked in the sun is gonna heat up regardless of paint color lol.
OK, because heating is a big drain in the winter, hence heated seats and steering wheel, my choice of the Cajun Red should help a little with heating.
Yes, as Feed the Trees stated, darker cars will get hotter in the summer. But the A/C is a very minor drain on the battery compared to the heater. It might make a difference of 15-25 miles depending on the outside temperature.
But the heater can easily lower your range over 25% if you have it running constantly.
The winter months here in Dallas are usually worst between late December and the end of March. I haven't had my Bolt long enough to know it's winter performance.
But on those days when temps are in the 40s or lower, I would pre-heat my Spark EV while it is plugged in every morning. Then once I was in the car, I turned on the defroster with the temp at "low". The seat heaters and defroster were enough to keep me warm. But it had far less of a negative affect on the range than if I just set the heater to auto.
The heated steering wheel will make this method even more effective!
Well, the only category in which this matters is in running the A/C or running the heater.
Given that Dallas has a lot more uncomfortably hot days than uncomfortably cold days, I think the most energy efficient colors will be silver or white, which will reduce the amount of heating inside your car when it's sitting in the sun, thus reducing the amount of use of the A/C.
However, that's just my guess. The counter argument would be that use of the heater sucks up a lot more kWh than use of the A/C, so you'd be better off with a black color to warm the car up on cold winter days.
But I think -- this is just my impression, I can't back it up with any figures -- the amount of heating contributed by a black color on the car is much greater on hot days than it is on cold days. Part of the reason for that is that there are fewer hours of sunshine on cold winter days than on hot summer days. That, at least, is indisputable.
It would be interesting to see a graph of kWh saved with a car colored black vs. a car colored white/silver, vs. average annual temperature, and also vs. number of annual days of sunshine.
A cold day in Dallas will still provide some thermal warming of the greenhouse so long as there is a decent amount of sun.
