My MINI Connected App no longer shows eDRIVE section, so I can't see my trip statistics. It was working fine yesterday, today it's gone. Has this happened to anyone else? I restarted my phone and still nothing.
Before and after:
View attachment 10501 View attachment 10502
Ditto.My relatively newly-installed Mini Connect app (Nov 2020) on my Android phone is v 6.5.0.6411 and still shows the eDrive section, at least as of this a.m.
I wonder if this change is emerging on the Apple version of the app? (@Puppethead's posted screen shots appear to be from an iPhone.)
Your experience brings to mind some wisdom imparted by Microsoft's original MS Word program:And like magic my eDRIVE is back. No update after my commute this morning, but after a quick jaunt at lunchtime I opened the MINI Connected app and watched as eDRIVE showed up. I suspect my SE was in a weird state and wasn't sending the eDRIVE data to the app.
It's a single app called "MINI Connected". You add your car via VIN. If it's not showing as an EV I'd suggest calling the MINI Assist number or check with your dealer.I am so confused. My Mini Connected app doesn't look anything like that. It shows "fuel level" in gallons and efficiency as "90 MPG". It is connected to my car (the right VIN and the right odometer reading). Where do I get the SE version for iOS?
Thanks. I will first try uninstalling and reinstalling. If that doesn't work, I'll make a call.It's a single app called "MINI Connected". You add your car via VIN. If it's not showing as an EV I'd suggest calling the MINI Assist number or check with your dealer.
Great! Just in time for the new app (see New MINI App thread). Latest I heard (unverified source) it is it's supposed to be released in March.Now I finally have all the EV related stuff.
It's better than Honda's HondaLink app for our Clarity Plug-In Hybrid. MINI Connected works great on my cheap-o LG phone. Climatize Now works quickly and reliably for me, as do the battery-charging prediction and status. However, I'll admit those are the only two features I use.I hope the new Mini app is better / more responsive. How do I refresh vehicle status? I tried swiping down, and nothing happens. It only seems to update when I send a command (and not always even then).
Also, I will send a "climatise now" command, and the app gets stuck on that screen, showing "sending". I cannot do anything else because a command is being sent. This continues even after I confirmed the car is actually warming up. Closing/ reopening the app seems to make it worse.
Generally, it's a poor app. I've had EV apps from Ford, Chevy, and Nissan. This one is near the bottom (although they are all pretty poor)
