Donald Rapp
There are two indicators. One is the digital miles remaining. I talked with Honda Central. This does not (I repeat NOT) tell you the charge of your battery. It does a computer calculation, based on past recent driving of how many miles you can expect if you drive the same way. And by experience, it is usually wrong. The other indicator is the bar chart at the left of the dashboard. This does tell you the relative charge but it is not specifically quantitative. I have a 2018 Clarity with 27,000 miles. The digital display might say 35 miles, or sometimes 39 miles when the bar chart is at the top. Experience teaches that even though the digital display might say 35 miles after fully charging, that is an underestimate. The bar chart still shows lines even when the display shows 0.0 and I can keep driving for at least seven miles with digital at 0.0. Conclusion: Don't trust the digital display. Rely on the bar chart.
