Puppethead
If I could find a good dual Level 2/Level 1 portable with UL certification I'd likely get it.Yeah, I’d be inclined to get a L2 portable charge cable if I were going to spend another $200.
Because most 120 V outlets in the US are on 15 A circuits (NEMA 5-15R), so a 10 A EVSE is the safest choice. My 2021 SE came with the same Level 1 EVSE.Why in the world would they cap it at 10 amps?
What's funny is that the default current is the "Low" setting, which is 6A for the 10A EVSE. So, they could have just included a 12A or 15A EVSE, since they could make the "Low" setting safe for anyone to use, and then the owner figures out how much they can increase that. Otherwise, why not just have it set to Max as the default?Because most 120 V outlets in the US are on 15 A circuits (NEMA 5-15R), so a 10 A EVSE is the safest choice. My 2021 SE came with the same Level 1 EVSE.
12A is the 80% limit for continuous load. Most cars come with an EVSE that pulls 12A from a NEMA 5-15.
I would argue that those two extra amps are even more important here since the car is so efficient.
Anecdotally, I moved from a 12A to 16A level 1 adapter in my Tesla and the difference was enormous, possibly due to electronics overhead in the car.
That's very true, but in this case the only difference would be the charging cable included with the SE. Which, as you point out, needs to happen anyway due to wall plug differences.The SE is an international car. Maybe 10A works for more markets than 12A? That way they make one EVSE for all markets, and only change the wall plug between them. Just a thought; I am not familiar with electrical standards outside of the US, I just know they differ.
Can someone explain this table from the owner's manual? I have the Mini-provided Level I charger pictured by Newkirk above in this thread ("10A max" is printed on the back of the EVSE but 15A is printed on cable). Assuming this means 10A for the "Imprint on the charging cable" in the table below, am I OK with simply choosing Max (10A) as the charge setting? Why would one instead choose "Reduced" or "Low", which I assume will result in slower charging.
Note that my circuit breaker says 20A and there is also a fridge running on the circuit. Tx!!!
If you're using the MINI EVSE, 10 Amps is the most it will deliver (and draw).
As you postulated, there would be no good reason to select a lower setting. Even with a fridge on the 20A circuit, you should be fine, assuming it doesn't pull 10A continuously, which it probably doesn't.
