Lane Departure
  • Thread starter Thread starter JohnT
  • Replies Replies 7
  • Views Views 90
JohnT
Hi
A couple of weeks ago; I started getting lane departure warnings. (I didn't before then)
I have checked the full manual and can't find a way to turn it off without also turning off cruise control.
I pulled the 12V battery power for 10 minutes which reset everything ... except the LKAS
Anyone have advice?
Thanks
John (2118 Touring 165,000 km)
Hi
Anyone have advice?
Thanks
Since 2017, I've always gotten lane departure warnings (wiggling steering-wheel) when my Clarity's camera sees me going outside my lane (at over 25-30 mph) without using the turn signal. I don't know how to turn those warnings off. Maybe you're referring to the beep?
The Owner's Manual (p. 326) says you can turn the beep on or off:
Thanks Insightman... - no, that's not it. (I turned beep off) but since 2018 I have NOT had the warning (wiggling wheel) Unless I pressed the 2 wide LKAS button - where the car 'sorta' self drives. Now the shake is on all the time unless I turn 'main' off which kills cruise control.
After disconnecting the 12V battery the guess-o-meter really screwed up.. Guess will have to wait a week or so for it to settle down!
It does sound like your Clarity is confused. By disconnecting the 12V battery, you took the only measure available to outsiders (owners) to reset the car's behavior. Sorry it didn't help.
Hi
Anyone have advice?
Thanks
What about turning off LKAS
Hi Neil - that is what I have been trying to do - maybe I have mistaken something. I 'want' the cruise control which follows the car in front and don't want lane departure. If you have the magic info I'd be very happy :-)
