DorisKnight
Hi - hope someone can help me. I’ve got a kona 2022 ev ultimate which i’m loving. When i drive, i select ‘Drive Info’ on the instrument cluster to give me data on the current trip between motor on and motor off. I’m getting a difference each time, however, between the miles/kwh reading on this central display and the miles/kwh reading at the bottom of the instrument cluster to the right of the horizontal moving bar display. Latter, as you know, shows immediate energy consumption and has a vertical bar line showing the average (for the current journey, I’m sure) and the number to the right of this bar does, i believe, give the value of this bar line. I have expected this lower right hand number to always match the ‘Drive Info’ value, but it doesn’t - and sometimes there are big +/- differences. i checked the manual, of course, and it did say that the ‘Drive Info’ value would average trips unless there was a 4 or more hour break between motor on and motor off. When i last compared the two values, i was on the first trip after a night’s sleep and the values were again different. Any answers, please/
