I get your point. I do most my miles within the 36miles battery range. Apart from the winter, most my miles are done solely on electric so my fuel costs are super low. And I know I can go on longer trips with the petrol engine. The hybrid would make more sense if I did more miles everyday. The transmission does make the car complex but it means it's normal to drive if you are shifting for the first timeI just don't see the point in this car for most folks. If you live in a warm climate, get an HOV sticker, or can get the car for less than the price of regular hybrid with tax credits, then the car makes some sense.
The think the 6 speed transmission makes the car over complicated for a PHEV, the lack of an electric heater makes the car a warm climate vehicle, and the battery is a bit too small.
Frankly, I think you buy a PHEV so you can drive the car the majority of the time as an electric vehicle and have a gas engine backup for longer trips. Without an electric heater, this car doesn't do that unless you live in a warm climate.
Go to the Honda Clarity forum and you will see how a PHEV should be designed.
EPA rated 26 miles, if you get in the car and the hvac fan is already on, the dash will show only 24 miles even if fully charged. I drive 35 miles round trip to work, the battery will get me 32-33 miles on a full charge before showing me zero EV range on the dash and kick into hybrid mode. Engine only kicks in if I floor it (rare) or if I use heat. Live in Chicago burbs.I’m seeing it is a 26 mile rated range?
https://www.kia.com/us/en/vehicle/niro-plug-in-hybrid/2018/plug-in
“The Niro Plug-In Hybrid delivers versatility right down to its power source. With the push of a button you can go all-electric using a high-density, lithium-ion polymer battery with an estimated EPA rated All Electric Range (AER) of 0-26 miles. And you can be confident knowing you'll never be stranded with its hybrid gas-electric HEV mode.”
