Kia media site - in depth specifications
  • Thread starter Thread starter LegoZ
  • Replies Replies 3
  • Views Views 7K
2020 Specs from above source:
ENGINE
Electric Motor - -
Motor Type AC Synchronous Permanent Magnet Motor
Voltage 356 V
Horsepower 201 hp (150 kW) @ 3,800-8,000 rpm
Torque 291 lb.-ft. (395 Nm) @ 0-3,600 rpm
ELECTRICAL SYSTEM
High-Voltage Battery Pack - -
Battery Type Lithium Ion Polymer Battery (LIPO)
Battery Voltage (V) 356 V
Battery Capacity (Ah) 180 Ah
Battery Energy (kWh) 64 kWh
Battery Power (kW) 170 kW
Weight 1,008 lbs.
Battery Cell Materials Nickel, Cobalt, Manganese (NCM)
Cooling System Liquid, via front-mounted radiator and A/C system
DRIVETRAIN
Transmission Type Gear Reduction Unit
Final Gear Ratio (Constant) 8.206:1
DYNAMIC PERFORMANCE
Max. Speed (mph) 104
Acceleration performance (sec) - -
0 - 62.1 mph 7.6
49.7 - 74.6 mph 4.8
Brake Performance (ft.) - -
62.1 - 0 mph 137 ft.
CHARGING
On-board charger (OBC) 7.2 kW
Port locations Behind front grille
Charging time - -
Level 1, AC charge with in Cable Control Box (ICCB) 59 hours (120V)
Level 2, AC charge with Electric Vehicle Supply Equipment (EVSE) 9 Hours 35 Min (7.2 kW)
DC fast charge with Electric Vehicle Supply Equipment (EVSE) to 80% charge 75 Min (50 kW) / 1 Hour (100 kW)
EXTERIOR DIMENSIONS
Wheelbase (in.) 102.4 in.
Length (in.) 165.2 in.
Width (in.) 70.9 in.
Height (in.) 63.0 in.
Track, front/rear (in.) 61.6 in. / 62.0 in.
Overhang, front/rear (in.) 34.1 in. / 28.7 in.
Min. Ground Clearance (in.) 6.0 in.
Approach Angle (degree) 16.2
Departure Angle (degree) 29.6
INTERIOR DIMENSIONS
Seating capacity 5 passenger
Head room - -
Front (in.) 39.9 in.
Rear (in.) 39.5 in.
Leg room - -
Front (in.) 41.1 in.
Rear (in.) 36.0 in.
Shoulder room - -
Front (in.) 55.5 in.
Rear (in.) 54.7 in.
Hip room - -
Front (in.) 53.5 in.
Rear (in.) 52.8 in.
Luggage capacity, rear seats upright, with luggage under tray (SAE, cu. ft.) TBD
Luggage capacity, rear seats folded, with luggage under tray (SAE, cu. ft.) TBD
Luggage capacity, passenger volume (SAE, cu. ft.) TBD
CHASSIS/SUSPENSION
Front suspension McPherson type suspension
Rear suspension Multi-Link
Shock Absorber (front/rear) Strut / Twin tube
STEERING
Type / Power Source Motor Driven Power Steering (MDPS)
Steering ratio 12.8:1
Turns, lock-to-lock 2.5
Turning circle, curb-to-curb (ft.) 34.8 ft.
BRAKES
Type front/rear Ventilated Disc / Solid Disc
Size (in.) front/rear 12.0 in. / 11.8 in.
Booster Type Electric Booster (Regenerative Brake)
Regenerative brake Motor polarity reversal
Parking brake Electric Parking Brake (EPB)
WHEELS/TIRES
Wheel size (in.) 7.0J x 17 Alloy
Tire size P215/55R17
Spare Tire Tire Mobility Kit (TMK)
CURB WEIGHT
Curb Weight, min (lbs.) 3,715
GVWR
Gross Weight (lbs.) 4,806
TOWING CAPACITY
Towing Capacity Not recommended
