I was simply talking about the estimated range shown on the car’s range estimate, not the EPA range. Two different things. The EPA estimate is static and the car’s estimated range is dynamic and ever changing.The EPA range certainly should not be taken as the range at 70 MPH. Even if you look at the separated city/highway ranges, rather than the combined figure, it's going to be less range than at 70 MPH. As I recall, the EPA's highway driving range tests average 55 MPH.
All cars rapidly lose range at higher highway speeds, gasmobiles included. (Aero drag increases as the square of speed, if I recall correctly.) It's just more noticeable for BEVs because their range is more limited.
As I've said many times, I wish the EPA would issue a range chart, rather than just a single number for range; a chart showing ranges at different speeds: 35, 45, 55, 65, 75, and perhaps even 85 MPH. That would really help educate the public on the advantages of using less energy, of driving at moderate speeds on the highway.
So my point was that the range estimate in my Tesla, regardless of whether I’ve switched from local driving to highway over the past days or week, is quite accurate, whereas on the Clarity it’s not. Driving at 70 in the Tesla takes much less of a toll on range estimates than it does in the Clarity. Explanations for the Clarity’s range fluctuations have been given here and I believe they are correct.
So knowing that I’ve been driving locally over the past week and will now be doing highway driving, will result in me throwing out the indicated 55 mile range estimate on the Clarity. That range was accurate for a continuation of local driving, not a sudden switch to highway driving. Armed with that awareness a Clarity driver should be fine. It just works very differently, and generally more accurately in a wide range of driving conditions, on a Tesla.
