Mini are really sandbagging the range and efficiency numbers of this car, and while it’s great to under promise and over deliver, the sticker range figure does put a lot of people off who day “I just wish it had a little more”, when I know it does!
That should be a carwow test in the UK. The extra range after 0% SoC is a mixed bag of BMS cell/module rebalancing and slow city driving.I have found that Mini has a few percent capacity hidden at both the top and the bottom. For example, I drive 3 miles and the car still reports 100% SOC. After another 3 miles, it reports 97% and proceeds to lose about 1% per mile (give or take).
On the low end, there was a video on YouTube where they drove the Mini for something like 20 miles on “0%” remaining.
At the same time, would those people really bite of the advertised range was 130 miles with caveats that it will be less under less ideal conditions? I think they made the right choice. Fewer customers maybe (maybe not) but far more satisfied and likely to return!
I need more info on this, care to share some links? My best friend placed an order for a Busyforks before the wheels fell off, but after the reports of slow fast charging. He’s still not dissuaded, regardless of how unremarkable — and now problematic — it seems.Toyotaru seems to have taken this approach. There have been Danish, Swedish, and Norwegian reports that the BZ4x is getting around half of the mileage that Toyota said that it would get. Granted, it is winter there now, but ...
I think he's referring to elbil24's review. One thing to point out that the busyforks only has a Guess O' Meter and no battery SoC % display. That is disturbing...I need more info on this, care to share some links? My best friend placed an order for a Busyforks before the wheels fell off, but after the reports of slow fast charging. He’s still not dissuaded, regardless of how unremarkable — and now problematic — it seems.
EPA rating says 367km for dual motor and WLTP is 461km so when Danish FDM real world tested 215km that is very reasonable with all the nice cabin comforts and the "new front-seat radiant foot-and-leg heater". Now if they tried at -22F and lower, that's a different story.correct. here's another link:
Toyota bZ4X: Cold Weather Tests Show a Much Shorter Range than Advertised - Motor Illustrated
elbil24 tested at 46.4F or 8C and FDM at 39.2F or 4C
I thought using BYD Blade LFP batteries was the hottest thing on the market...except LFP hates cold weather (needs active battery heating...). Nobody complains about the Tesla Model 3 SR using LFP, so why give Toyota such a hard time?Even using the lower EPA rating, that's more than 40% less. How is that very reasonable? That's equivalent to the SE having only 67 miles full range at 39F with climate control, seat heater and heated steering wheel turned on running on winter tires. That's unacceptable.
Reasonable is in light of the lithium anode choices, extra radiant heating, AND lack of SoC % display!
I will get 67 miles of full range probably at 14F with highway driving and probably 49 miles of full range at -30F in the SE.
Absolutely! I get 140+ miles in the summer in the SE and if I could get 45+ miles in -40F weather I'd be happy.But we are not talking about 14F or -30F, we are talking about 39F.
You will get a lot more than 67 miles at 39F in mid mode with climate control turned on with your SE.
