Independent mechanic experiences
  • Thread starter Thread starter Zubs
  • Replies Replies 10
  • Views Views 104
Zubs
Anyone had any problems taking the SE to an independent mechanic?
My 2023 SE is done with the 3 year included maintenance. I don’t like the BMW dealership in my area and would prefer to use anyone else.
I started calling around and found out only about 30% of Mini mechanics in my area will service the SE. The one I’m trying out said they can handle everything unless it is specifically EV or battery related.
At 4 years old the car is only calling for the standard inspection and a brake fluid change so I’m guessing I’ll be fine for now.
Because the SE is built on the long-standing F56 platform it should be easy to find independents who can fix any of the mechanical, body, and interior stuff. It's almost all identical to the gas versions.
Also, other than for the electrical drivetrain, parts for the long-run F56 platform are going to be easier to find than for an EV with a smaller production run. I found that a comforting factor when I ordered my MINI Cooper SE. Body parts--or even new OEM carpets--for the unique 2000 and 2006 Honda Insight hybrids I used to drive are nonexistent now.
I got an email from Acura they will now start remanufacturing 3000 different parts for the 1991-2005 Acura NSX. I wonder if they will do the same for the Insight ? I heard the NSX and Insight were built in the same factory in Japan...
Apologies in advance for going off topic......
Worth keeping a dealer option in your back pocket even while using the independent for routine service. Brake fluid flushes, suspension, tires and similar work are generic, but firmware/ECU updates and any high-voltage diagnostics or battery health checks generally need MINI's ISTA setup, which most independents don't have. Some shops also decline anything that involves touching the orange cables, even for unrelated jobs. Your 25% figure sounds typical — dealer labor rates around where I am run two to three times what a good independent charges.
"Parts". Eventually, it's all about finding replacing parts. Although it is good knowing that there are aftermarket places like Bumblebee Batteries that can offer a replacement battery for your Gen 1 Honda Insight Hybrid, at some point you find it difficult to a get a certain part. It almost forces one to get something new.
"Parts". Eventually, it's all about finding replacing parts. Although it is good knowing that there are aftermarket places like Bumblebee Batteries that can offer a replacement battery for your Gen 1 Honda Insight Hybrid, at some point you find it difficult to a get a certain part. It almost forces one to get something new.View attachment 29211
Sadly, Bumblebee Batteries is no longer in business.
Thanks for the photo of the Insight. Even after driving them for 20 years, I still get excited whenever I see one. A month ago, I enjoyed meeting the owner of a 2000 Citrus Yellow Metallic Insight as we were both visiting Zingerman's Bakehouse in Ann Arbor. He was also a glider pilot, which seems a perfect hobby for a gen-1 Insight owner.
