ICE odometer?
  • Thread starter Thread starter Hobbesgsr
  • Replies Replies 6
Hobbesgsr
Is there an odometer or something specifically for the gas engine to track how many miles/kms it’s been driven?
I know the service minder will tell you when to change the oil etc but it would be useful to know how much the ICE has been used.
You might take a look at the thread, What should the break-in period be for the Clarity? If Honda records mileage or engine hours, we don't yet know how to retrieve that information. I've installed an hour meter to provide a run time indication.
I was hoping to find a tachometer somewhere in the computer for the ICE but I guess since we have no control over how high the engine revs, Honda decided we didn't need to know that information. Of course, the car knows all the time what the engine rpm is, otherwise it could blow itself up.
I have a Bluetooth OBD2 dongle with the Android Torque app. I wonder if that will read ICE RPM and electric motor RPM and display in gauge mode?
I forget where I found it, but there is a collection of Xgauge settings to use with the Scangauge II that appears to be compatible with the Clarity. It requires the 4.50+ firmware, which I don't yet have. It doesn't offer any accumulated data, like hours or miles.
Edit: This is for Honda/Acura Hybrids. I haven't tested any of them on the Clarity.
Limited success using the same Xgauge settings as I did on the PriusPHEV. No temp readings, limited RPM range. All others like MPH, etc. work. Maybe I'll try the Honda/Acura settings. Seems like it might be closer to reality than Toyota's.
