I know this sounds unhelpful, but bear with me. You haven't lost anything Chuck! The full battery is exactly as full of energy today as it was on the day you bought it. Also, even though on day one the range said 260, and today it says 200, it will still take you exactly as far as it would on day one (IF the driver and driving conditions were the same).
I think the confusion that people have (and many have it - you're not alone) is based on thinking that the remaining miles indicator on the dash is like a gas gauge. It's not.
That Range indicator (often referred to as the GOM or Guess-o-Meter) is not a measure of how much charge you have in the battery. When you fill up your 2-month old electric car and the GOM shows 200 miles instead of the 260 that it showed when new, it's not the same as if you filled up your 2 month old gas car and the tank needle only went to 7/8ths full. The GOM is not telling you how big the battery is - it's just telling you how many miles you squeezed out of the last full charge (on average). It's all about driving conditions, not about battery condition (at least for a fairly new car).
The GOM is reporting an algorithm that takes 64 kWh, and divides it by your average energy consumption which is reported to the right of your speedometer, in miles/kWh (the equivalent of fuel economy for a gas car.). When you bought your car, the computer used an average guess at efficiency (something like 3.8 m/kWh), and multiplied that by a full charge. That equals about 260 miles of range on the Guess-o-meter.
You can watch the GOM changing it's guess if you just turn on the heater. The GOM will drop by double digits. That's not because the battery got any smaller or less healthy - it's just that the car thinks "he's going to use a bunch of electricity to heat the cabin now" and it gives you a new guess of you how far you'll be able to go with the heat on.
If you drive fast, or accelerate hard, or drive with the heat on, then you can very easily average less than the original 260 reported range. As the car adjusts it's expectations based on your first couple weeks of driving you'll see the full GOM miles decrease. That doesn't mean the battery has degraded, because the GOM is not a battery gauge.
If you drive in warm weather, use a hyper-miler driving style, keep speeds below 60, etc, then you can very definitely exceed the original GOM distance. The battery is exactly the same in both situations. The GOM is just reporting a range prediction based on your recent efficiency history.
If you want to check how your driving history has been, open the EV page on the infotainment screen, and choose . . . I forget, is it "driving history"? Anyways, you can see a log of your past trips' efficiency (m/kWh if it's an American car), and if you see a lot of 3.0, 3.1, 2.9 etc, then your 200 mile GOM is showing you how far YOU go on your full, healthy 64kWh Battery.
(If there were a problem with your battery's health or capacity, then you would expect to see higher efficiency, but lower range performance.) If you're regularly getting 4.0 and higher, and your range on the GOM is 200, then maybe there's a battery problem, but this is likely not the situation you're in.)
