teslarati97
The AC button should activate "air conditioning" mode from the chiller, effectively running the loop in reverse. As for the mythical "heat pump" dehumification, that does not exist because the water condensate is a self-contained closed system.I've wondered about this as well. When I'm heating the cabin, what does the AC button do? Is it a way to activate/deactivate the heat pump? Or is the heat pump being used either way and the AC button helps dehumidify or something?
Household heat pumps systems generally have interior and exterior condensate drain lines but it would be bad news bears frozen-line-no-heat for EVs.
