Here is my observations from a 805 mile trip over several days about 30 EV miles included. Started with full tank of gas and nearly full charge ended with full tank of gas and no EV range remaining. Car loaded with about 400lb of humans and 150lb of gear (550lb total). Generally heat set to 68 as I figured it was almost free since
ICE was running.
Actual MPG 39.93 mpg calculated 805 miles/20.159 gallons of fuel
GOM trip computer calculated 44.6 mpg
Details
Leg 1 EV nearly full 173 miles 3.732 gals of gas = 46.35 mpg. Temps were in the Mid 40's speed was in the 60-70 mph on the highway terrain level (Chicagoland to South Haven MI).
Leg 2 EV nearly full 190 miles 4.939 gals of gas = 38.47 mpg. Temps around 40 speed was 70-80 mph on the highway some terrain (South Haven to Traverse City MI). Note when speed was in upper 70's the engine was really humming when on level or up hill, much more so than in the low 70's.
Leg 3 EV down to 8 miles (4 bars) 244 miles 6.238 gal of gas = 39.12. Temps in mid 20's speed around 70 mph on the highway some terrain (Traverse City MI to Kalamazoo MI).
Leg 4 EV range 0 - (two bars) 198 miles 5.250 gals of gas = 37.71 mpg. Temps were 35 speed was 70 mph for about 130 miles and 65 mph of about 60 miles terrain was level (Kalamazoo MI to Chicagoland). Did notice the GOM estimate of mpg was in the 38-39 range at 70 mph and got to the low 40's when I dropped down to 65.
Notes:
- It's hard to preserve EV charge as every time you stop and turn off/on car and reset HV mode it seems to want to loose a little before it settles into it's new level
- Speed saps mpg. 60-65 mph looks to me will beat the projected 40 mpg rating while 70 seems to yield about 40 mpg
- No challenges going 80 mph but it does make that little engine work pretty hard compared to slightly lower speeds
- Seems like having some charge above 2 bars has a positive impact on mpg.
Please comment.
