Not quite. You'd have to remember to push the button for HV every time you turned out on, and it can't actually keep the charge at the exact same point. On a trip from Texas to Alabama, HV all the way aside from a few consecutive seconds before I push the HV button after stopping for gas, it still goes through plenty of the battery. At 15¢/kWh, for about 3 miles per kW, means gas at 45 mpg must be below $2.25 to match. But if you don't have a plug at all... It does get great mpg on gas for being a big roomy sedan, and you can always switch to "HV charge" if you're worried the battery is too low.I live in an apartment, and I don't have easy access to a charger. If I charged the Clarity once, and never took it out of HV mode, would that maintain the battery at around 50% indefinitely? I know the car doesn't drive very well with a dead battery.
In my experience, HV mode does pretty well at holding the state of charge.The battery still drains even in HV mode?
I thought HV mode in the Clarity was like hold mode in the Chevy Volt. It holds the current battery state of charge. The battery still drains even in HV mode?
For example, if I drive up a steep grade, EV miles will drop significantly.
This behavior has been well documented on this forum. Have you driven the car a sufficient distance on flat terrain, after driving uphill and observed EV range? It may take 5 or more miles, but it will return to the set point.
1. If I fully charge the battery and then immediately drive it in HV mode on the freeway at 65 MPH, even on flat terrain, it typically immediately loses a few miles of charge.
2. After driving in HV up a steep hill, and then driving 20 miles or so on fairly flat terrain (or back downhill) at less than freeway speeds, the vehicle still has lost a few miles of EV charge.
The above chart also confirms the Honda’s mpg estimates are consistently about 12% optimistic, which I still think must be intentional - and deceptive.
For your situation I’d recommend the following.
1) After a full charge, use at least one bar off the top of the battery gauge, or 3-4 miles of EV range. This will prevent regenerative braking energy from starting the engine.
Honda's Insight and Accord hybrids, use the starter motor/generator turn a deadened engine to use up excess regen energy that cannot go to the fully charged battery. That ploy wasn't continued in the Clarity PHEV. Perhaps it has something to do with the Clarity's greater weight; perhaps it has something to do with the Clarity's larger battery--I cannot think of any other differences. What the Clarity does is burn gasoline running the engine to use up excess regen energy that cannot go to the fully charged battery. No one from Honda has explained this mysterious behavior.Do I have to drive 3-4 miles without using the brakes after 100% SOC to keep from starting the engine?
