Calling all experts!
Ok, I want to ask the auto experts out there (ok, those here) with experience in the industry regarding warranties. I think it is applicable to this thread. I'm not talking about the Magnuson-Moss stuff. I mean where you need to show that you maintained your vehicle (even if you did your own oil changes etc) in accordance with the manufacturers guidance in order to your factory warranty to remain in force.
In my personal industry, where most of my expertise is, we get OEM Service Bulletins, Service Letters, Air Worthiness Directives (you can guess those are not optional by the name) etc. They come in flavors of OPTIONAL, RECOMMENDED, MANDATORY, and the occasional LIFE LIMITED CRITICAL (comply within 5 hours of issuance). The effect of or on warranty depends.... Some are from the stance of the work, the bulletin is covered under warranty. Some are issued where if you do not comply - your warranty is immediate forfeit as is the legality to fly the machine. So....
Our vehicle's have different requirements as do OEMs. To my knowledge, none of the these bulletins say anything about warranty other than if improperly applied, or applied by the owner that Honda will not reimburse costs or be "responsible" for compliance. If the NHTSA puts out a safety recall, the OEM has to make the repairs period. So there are obviously times when the OEM will be required to provide coverage for a failure by a regulating authority.
However, if you decide to not do a service update (as this thread is about), is there a time where the OEM can say, well we told you and you said no, so nothing on this "system" effected is covered under warranty. My "specific" example would be the EWV 18-090 bulletin. Where based on Honda's data and my anecdotal observations I can easily play devils advocate and see a situation where Honda could deny your HV Battery warranty if you never complied with that letter after it was documented you said no (at a dealer). I am not saying that will happen, but I can see where there is reasonable argument if your pack failed slightly early (15% prior to your end of warranty) the OEM could and would likely want to point to any valid reason to deny a claim. The warranty act mentioned above basically says they have to prove what you did or didn't do actually contributed or caused the failure. In the situation above (although you would have to also ignore a lot of dash warnings) that coolant valve error can be a reason for HV pack premature failure...
So, based on this - does anyone with industry experience (previous dealer, mechanic, insurance, service writer, end user effected, etc) think this is a valid concern?
I also I firmly believe that "user experience" improvements are not part of this concern. If you don't want to update the Driver Range Display, or the commercial charging hiccup patch, that is up to you as it only results in your owner experience changing - not a post manufacturing defect identification.
Cheers,
Cash
