K Kia Guy Active Member Jul 13, 2021 #1 There used to be an option to change the indicator light from 3 seconds, to I believe, 5 seconds. I cannot locate this anymore on my 2019 Niro. Any idea where it went?
Esprit1st Well-Known Member Jul 13, 2021 #2 In Kona it's 3, 5 or 7 blinks for the touch indicator. It's in the instrument cluster menu.
K Kia Guy Active Member Jul 13, 2021 #3 Esprit1st said: In Kona it's 3, 5 or 7 blinks for the touch indicator. It's in the instrument cluster menu. Click to expand... I presumed it was in the Instrument cluster. Where exactly though?
David T in Silicon Valley Active Member Jul 14, 2021 #4 Does "indicator light" = turn signal? Not sure what you are referring to
Esprit1st Well-Known Member Jul 14, 2021 #5 In the Kona it's under: User settings/Lights/One touch turn signal
K Kia Guy Active Member Jul 15, 2021 #6 David T in Silicon Valley said: Does "indicator light" = turn signal? Not sure what you are referring to Click to expand... Yep, that's the one.
C CodysEv New Member Jul 17, 2021 #7 Lights>one touch turn signal Sent from my iPhone using Inside EVs
K Kia Guy Active Member Jul 17, 2021 #8 Yep, found it. I don't know what I was thinking to have missed it... it's pretty obvious!
