One reason that I still put my Clarity in HV mode early: I use an HV reset to keep the RPM down, and this is not possible with zero EV remaining. This is only important for long hills, or with the heater running.
I am able to keep the RPM below 3,000 - even up to 80 mph, on 'all' roads.
Not sure what is meant by HV reset, I'm guessing this means using charge mode to increase the EV range, then turning off HV then turning it back on again to reset the target SOC to the new higher value?
For hill climbing if you experience that you have lower RPM's on a long hill climb with EV miles than with 0 EV miles, then you should also see the EV range drop quite a bit during the hill climb, more than it normally would in HV mode. Is that what you are seeing? The problem in comparing the two scenarios is, at least for someone without access to RPM and SOC data, is that at 0 EV range the display no longer shows you any changes to SOC like it does when you are above 0 EV range, so it all becomes subjective based on our eardrums, and we have people saying that they get lower RPM's with EV range than without, then some say later they can't duplicate it, and others don't experience any difference. I think actually tracking like you are doing by more people in repeatable driving scenarios is the only way to prove things.
The theory would be that in certain driving conditions the system is less aggressive in maintaining SOC when you have EV range, meaning that in some situations it will "borrow" more power from the battery than it normally would since it knows that it is in no danger of getting near 0%. Whereas at say 10% SOC and you are in a sustained hill climb, it will only borrow the normal few percent and after that ICE is on its own.
This could also explain the anecdotal EV "leakage" as I call it that some people report in HV mode on a long drive, where EV range slowly goes down. A similar theory might explain that, with plenty of EV range the HV system sometimes borrows more than normal, which it intends to pay back, but if it never finds enough efficient moments to pay back the borrowed SOC then it eventually just resets itself to the new lower level. But that is just a guess of an explanation for a phenomenon that again is more anecdotal than documented.
And on top of that we believe that at least in the past some people experienced a software glitch when SOC was at 10% or below which caused the system to unnecessarily panic and go into angry bees mode, or even worse a limp mode where it only allowed enough traction power to move off the highway with all the rest of the high powered revving going towards charging. Both of those problems however appear to have been solved through software updates as we no longer hear about them, but the residual effect is that because of those past reports people still worry about running out of EV range.
I don't discount out of hand anything anyone experiences, the question is whether a particular phenomenon is an anomaly experienced occasionally by some, or how the car normally works. So far I think it points towards the former not the later in most cases, but it could also be that there are some subtle things about the car that we haven't fully understood yet.
